LaTeX Tip: Displaystyle with Bigger Expressions
  • Context: LaTeX
  • Thread starter Thread starter alexmahone
    Latex
5 replies · 39K views
alexmahone
Use \displaystyle in the beginning for bigger expressions.
Normal: $\sum\frac{n^5}{2^n}$
Using \displaystyle: $\displaystyle\sum\frac{n^5}{2^n}$
We had this same issue on MHF as well.
The thing is that single dollar sign delimiters $\displaystyle \frac{x}{y}$ are for in-line maths-notation, making it larger means that the maths will foul the text in following lines.
Or make the line spacing irregular, though you have too keep typing for a long time to get test wrapping to test this
More uses for \displaystyle . . .\lim{x\to3}\frac{x^2-9}{x-3} . . . . . . . . . . . . . $\lim_{x\to3}\frac{x^2-9}{x-3}$
\displaystyle \lim_{x\to3}\frac{x^2-9}{x-3} . . . $\displaystyle \lim_{x\to3}\frac{x^2-9}{x-3} $sum^{\infty}_{n=1}\frac{1}{n^2} . . . . . . . . . . . . . $\sum^{\infty}_{n=1} \frac{1}{n^2}$
\displaystyle \sum^{\infty}_{n=1}\frac{1}{n^2} . . . $\displaystyle \sum^{\infty}_{n=1}\frac{1}{n^2}$\int^3_1 x^2\,dx . . . . . . . . . . . . $\int^3_1 x^2\,dx $
\displaystyle \int^3_1 x^2\,dx . . . $\displaystyle \int^3_1 x^2\,dx$
If \displaystyle makes a fraction too large:
. . \displaystyle \frac{x-3}{x+4} + \frac{1}{2}x^3 . . . . $\displaystyle \frac{x-3}{x+4} +\frac{1}{2}x^3$
it can be reduced with \tfrac:
. . \displaystyle \frac{x-3}{x+4} + \tfrac{1}{2}x^3 . . . $\displaystyle \frac{x-3}{x+4} + \tfrac{1}{2}x^3$
If you want to displaystyle fractions, it's easier to use the \dfrac{}{} command.
\frac{x+1}{x-1} yields $\frac{x+1}{x-1}$, but \dfrac{x+1}{x-1} yields $\dfrac{x+1}{x-1}$
So in the example you provided, we could say \dfrac{x-3}{x+4} +\frac{1}{2}x^3, which would give $\dfrac{x-3}{x+4}+\frac{1}{2}x^3$ (thus, \tfrac{}{} can be avoided in the inline case). I would say that the \tfrac{}{} option is most useful in scenarios when the rendered code is centered by $$ or \[ (the cases where the equations are automatically displaystyled).
Hello, Chris L T521!
I did know all that . . . and didn't get around to explain it,
. . but thanks for clarifying it.I intended the \tfrac feature to be used when \displaystyle must be used.$\displaystyle \text{Here's an example: }\:\int^5_3\frac{x^2-4}{x-2}\,dx$
To produce the large integral sign, I used \displaystyle.
. . It also produced the large fraction.
. . $\displaystyle \int^5_3\frac{(x-2)(x+2)}{x-2}\,dx \;=\;\int^5_3(x+2)\,dx \;=\;\frac{1}{2}x^2 + 2x\,\bigg]^5_3 $To me, the $\dfrac{1}{2}$ seems awkwardly large (but maybe that's just me).
. . I would use \tfrac here.
