Laurent series expansion of ℘(z).
The discussion centers on the Laurent series expansion of the Weierstrass ℘ function, specifically the transition from the expression ##(1 - \frac{z}{w})^{-2}## to its series representation. Participants clarify that the correct expansion is given by the series ##(1 - t)^{-2} = \sum_{n=0}^{\infty} (n+1)t^n##, which can be derived from the binomial theorem and differentiation techniques. The conversation highlights the importance of accurately applying the binomial expansion and understanding the negative binomial coefficients in this context.
  • Understanding of binomial expansions, specifically negative binomial series.
  • Familiarity with Maclaurin series and their applications.
  • Knowledge of the Weierstrass ℘ function and its properties.
  • Basic calculus concepts, including differentiation of power series.
  • Study the derivation of the binomial series, focusing on negative binomial coefficients.
  • Learn about the Weierstrass ℘ function and its applications in complex analysis.
  • Explore the use of Pochhammer symbols in series expansions.
  • Investigate advanced techniques in series convergence and manipulation.
Mathematicians, students of complex analysis, and anyone interested in series expansions and their applications in elliptic functions.
binbagsss
[/B]
Hi,
I am trying to understand the 2nd equality .
I thought perhaps it is an expansion of ##(1-\frac{z}{w})^{-2}## (and then the ##1## cancels with the ##1## in ##( (1-\frac{z}{w})^{-2}) -1 ) ##) in the form ##(1-x)^{-2}##, however this doesn't give me the right answer, can someone please help explain how they got from line ##1## to ##2## ?
Many thanks in advance.
binbagsss said:
[/B]
Hi,
I get the right answer when I expand ##(1 - (z/w))^{-2}## in a Maclauren series about ##z = 0##, or use the binomial expansion involving the "negative binomial" ##C^{-2}_n##. It sounds like that is what you did too, but got the wrong answer for reasons you do not explain, using work that you do not show.
oh okay, thank you for your reply.
So for ##(1+x)^{-2}## where ##x= \frac{z}{w}## is of the form ##1+nx+\frac{n(n+1)x^2}{1.2}+\frac{n(n+1)(n+2)x^3}{1.2.3}+... ##I don't know how to express this as a summation over ##n## unless it simplifies somehow for the case here ##n=2##
you know me well...
What does called ?
So for ##(1+x)^{-2}## where ##x= \frac{z}{w}## is of the form ##1+nx+\frac{n(n+1)x^2}{1.2}+\frac{n(n+1)(n+2)x^3}{1.2.3}+... ##I don't know how to express this as a summation over ##n## unless it simplifies somehow for the case here ##n=2## you know me well...
Your expansion is wrong. It should be
$$(1-t)^{-2} = 1 + 2 t + 3t^2 + 4 t^3 + \cdots = \sum_{n=0}^{\infty} (n+1)t^n.$$
Note that ##(1-t)^{-2} = \sum_n (-1)^n C(-2,n) t^n##, and ##C(-2,n) = (-1)^n (n+1).##
Of course, you can also get it by looking at
$$(1-t)^{-2} = \frac{d}{dt} (1-t)^{-1} = \frac{d}{dt} (1 + t + t^2 + \cdots)$$
Apologies it should have read ##(1-x)^{-2}## , wrong sign, but plugging in ##n=2## gives cancellations to give the same as your expansion there
Can I just ask, for general ##n## there is no simplified general expression as a summation ?
For example considering ##n=3## the most I can simplify this to is:##1+3x+\frac{(3)(4)x^2}{(2)(1)}+\frac{(3)(4)(5)x^3}{(3)(2)(1)}+\frac{(3)(4)(5)(6)x^4}{(4)(3)(2)(1)}+\frac{(3)(4)(5)(6)(7)x^5}{(5)(4)(3)(2)(1)}+...##
##=1+3x+6x^2+\frac{(4)(5)x^3}{(2)(1)}+\frac{(5)(6)x^4}{(2)(1)}+\frac{(6)(7)x^5}{(2)(1)}##
##=1+3x+6x^2+\sum\limits_{k=3}^{k=\infty} \frac{(k+1)(k+1)x^k}{2} ##
so for a general expression the ##x^{n-1}## terms will not be included in some general summation? (for ##n## integer)Is there a more simplified way to write this or not?
Many thanks.
9K
