Mastering Laurent Series Expansion: A Layman's Guide
This discussion focuses on the process of mastering Laurent series expansion, specifically through the example of the function f(z) = -1/3[3(z+1)] + 4/3[z+4]. The user breaks down the function into partial fractions and successfully derives the series expansion for the term 4/3(z + 4) using the geometric series formula. The conversation also clarifies the distinction between Laurent and Taylor series, emphasizing that a Laurent series can include negative powers, particularly in the context of poles, such as the pole at z = -4 in this case.
  • Understanding of complex functions and series expansions
  • Familiarity with geometric series and convergence criteria
  • Knowledge of Taylor and Laurent series definitions
  • Basic algebraic manipulation skills for partial fractions
  • Study the convergence criteria for Laurent series in complex analysis
  • Learn the differences between Taylor and Laurent series in detail
  • Practice deriving Laurent series for various functions with poles
  • Explore applications of Laurent series in residue theory and contour integration
Students and educators in mathematics, particularly those focusing on complex analysis, as well as anyone seeking to deepen their understanding of series expansions and their applications in mathematical analysis.
j-lee00
In attachment
I break into partial fractions, then get stuck. Please help me in layman terms
Now I am stuck.
Hi!
I will help you with a full list of steps for one of the parts:
<br /> <br /> \frac{4}{3(z + 4)} = \frac{4}{3(4(\frac{z}{4} + 1))} = \frac{1}{3(\frac{z}{4} + 1)} = \frac{1}{3(1 + \frac{z}{4})} = \frac{1}{3}\cdot \frac{1}{(1 + \frac{z}{4})} = \frac{1}{3}\cdot\frac{1}{(1-(-\frac{z}{4}))} = \frac{1}{3}\left ( 1 + (-\frac{z}{4}) + (-\frac{z}{4})^{2} + (-\frac{z}{4})^{3} +\cdots \right ) = <br /> <br />
<br /> <br /> = \frac{1}{3}\left ( 1 - \frac{z}{4} + \frac{z^{2}}{4^{2}} - \frac{z^{3}}{4^{3}} +\cdots \right ) = \frac{1}{3} - \frac{z}{3\cdot 4} + \frac{z^{2}}{3\cdot 4^{2}} - \frac{z^{3}}{3\cdot 4^{3}} +\cdots<br />
Remember that for a given geometric series to converge |x| has to be less than 1. which in your case means:
<br /> \left |\frac{z}{4} \right |&lt;1<br />I hope you will understand all the steps otherwise do ask.
P.S. I used the sum of the geometric series (which is also the Taylor and Laurent series): 1/(1 - x) = 1 + x + x^2 + x^3 + ...
|x|<1
Thanks for your help.
With the expansion that you made, how does this differ to the taylor expansion? or it the same?
If a Laurent series contains only non-negative powers, it will be identical to the Taylor series for the function.
Are the negative powers of the Laurent expansion only as big as the largest pole?
What do you mean by "largest pole"?
Note that
\frac{4}{3(z + 4)} = \frac{1}{3} \left( 1 - \frac{z}{4} + \frac{z^2}{4^2} - \frac{z^3}{4^3} + \cdots \right)
has a pole at z=-4 yet no negative-power terms. The Laurent series about z=0 of the function for |z|>4 is
\frac{4}{3(z + 4)} = \frac{4}{3z}\left( 1 - \frac{4}{z} + \frac{4^2}{z^2} - \frac{4^3}{z^3} + \cdots \right)
has an infinite number of negative-power terms.
What you wrote clarified my problem. tks
