Learning PDEs from Scratch in 24 Hours
  • Thread starter Thread starter imsleepy
    Pdes scratch
34 replies · 6K views · last reply
ehh my head's not working, i should go to bed soon.
Photo of a printed homework sheet with a Fourier series ODE d2y/dx2 + 10y = f(x) and problem 4, a Laplace PDE on a rectangle 0 < x < L, 0 < y < H with boundary conditions du/dx(0,y)=0, u(L,y)=1, u(x,0)=0, u(x,H)=0.
question 4. no clue.
H and L are just arbitrary points on the y and x-axis respectively, i presume..
what do each of those initial constraints mean, please?
and how do i know what is insulated?
ok found some stuff in my notes.
i think the du/dx (0,y) = 0 line tells you that something is insulated.
i've done some question in my book (obviously lecturer has done it and i was merely copying it, lol), and i have written down:
uxx + uyy = 0
u(0,y) = 0
u(a,y) = 0
u(x,0) = x (maintain temp-profile 'x')
du/dy (x,0) = 0 -> temp gradient perpendicular to side on bottom is zero, ie. no heat can flow across side => INSULATED
i might've missed something because my graph has a 'b', and i see no b's written in the question, but main thing is that from this i can gather that with question 4, the du/dx (0,y) = 0 line tells me that something is insulated :)
now to find out what side is insulated...
du/dx (0,y) = 0
so, gradient at 0,y is equal to 0?
would this be just the y-axis (up to point H) that is insulated?
Handwritten separation of variables solution of Laplace's equation on a rectangle 0<x<L, 0<y<H, with boundary conditions, a labelled sketch of the rectangle with H and L marked, and steps leading to X''/X = -Y''/Y = k.
from there onwards, i simply cannot understand what worked solutions are doing >_<
in you question i think a=L, b=H as you have
0<x<L, 0<y<H
the insulated side is the one where the derivative is held at zero,
