How Does the Least Squares Estimator Minimize Error in Linear Regression?
  • Thread starter Thread starter squenshl
    Estimate Square
The discussion centers on the least squares estimator (LSE) in linear regression, specifically how it minimizes error. The problem states that the residuals can be expressed in terms of both the true parameter vector and the estimated vector, leading to a relationship that must be proven. Participants express confusion over the terminology distinction between "estimator" and "estimate," questioning the problem's formulation. They suggest using substitution to expand the residuals and identify conditions under which the first-order terms vanish, confirming that the LSE minimizes the error. The conversation highlights a deeper exploration of the mathematical foundations of linear regression and the implications of parameter estimation.
squenshl
Suppose that ##Y \sim N_n\left(X\beta,\sigma^2I\right)##, where the density function of ##Y## is
$$\frac{1}{\left(2\pi\sigma^2\right)^{\frac{n}{2}}}e^{-\frac{1}{2\sigma^2}(Y-X\beta)^T(Y-X\beta)},$$
and ##X## is an ##n\times p## matrix of rank ##p##.
Let ##\hat{\beta}## be the least squares estimator of ##\beta##.
Show that ##(Y-X\beta)^T(Y-X\beta) = \left(Y-X\hat{\beta}\right)^T(Y-X\hat{\beta})+\left(\hat{\beta}-\beta\right)^TX^TX\left(\hat{\beta}-\beta\right)## and therefore that ##\hat{\beta}## is the least squares estimate.
Hint: ##Y-X\beta = Y-X\hat{\beta}+X\hat{\beta}-X\beta##.
I have no idea where to start. Do I substitute the hint into ##(Y-X\beta)^T(Y-X\beta)## and expand out the brackets?
Please help!
There seems to be something odd about how this problem is stated. It asks the student to assume that ##\hat\beta## is the least squares estimator of ##\beta## - and then to use that to prove that it is the least squares estimate. Are they trying to draw a distinction between estimator and estimate? If not, the problem is trivial. However if we want to get very precise about terminology I would have thought that an estimator is a function whereas the estimate is the result of the function. Is there some particular meaning of 'estimator' and 'estimate' that they are using in your course?
As to how to proceed to prove their formula, yes substitution along the lines you mention sounds a good way to start. You can rewrite the RHS of the hint as ##(Y-X\hat\beta)+X(\hat\beta-\beta)##. Expanding out then gives us a right hand side that is what they show above, plus
$$2(X(\hat\beta-\beta))^T(Y-X\hat\beta)$$
So this needs to be shown to be zero. However it seems to me that should be impossible, since it is a function of the unknown parameter vector ##\beta##, which can be changed without changing any of the other elements in the formula (##X,Y,\hat\beta##) .
Are you sure there wasn't an expectation operator around that equation they want you to prove, or some other constraining condition?
Nope that's the question asked.
Please help!
Let ##Q(\beta) = (Y - X \beta)^T (Y - X \beta)##. If you write ##\beta = b + e## you can expand ##Q(b+e)## as a quadratic in ##e##. It will have 0-order terms (not containing ##e##), first-order terms (linear in ##e##) and second-order terms (of the form ##e^T M e## for some matrix ##M## that depends on ##X, Y## and ##b##). However, if you choose ##b## correctly, the terms of first-order in ##e## will vanish, leaving you with only zero-order and second-order terms in ##e##. That will happen when ##b = \hat{\beta}##. You will obtain the expression you are being asked to prove, where ##e = \beta ##-
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
