Legendre polynomials in the reverse direction
2 replies · 2K views
ognik
I have just written a program to calculate Legendre Polynomials, finding for Pl+1 using the recursion (l+1)Pl+1 + lPl-1 - (2l+1).x.Pl=0 That is working fine.
The next section of the problem is to investigate the recursive polynomial in the reverse direction. I would solve this for Pl-1 in terms of Pl and Pl+1 - could someone please confirm if that is the correct way to 'reverse'? Also I would use the Rodriques formula to get the 2 starting values of Pn and Pn-1, it's a complex formula, is there a better way to get those starting values? Thanks for all help.
Hi again - I found enough to convince me that solving for Pl-1 is the correct way to calculate in the reverse direction. I also decided against using the Rodriguez formula, since I work out Pl and Pl+1 in the forward program, I can just use those as starting values for the reverse direction. All seemed good. However what I expect in the reverse direction, is to get P(x) for l=1, which should be always x. I figured that the last 2 P values correspond to L_input and L_input - 1, so loop down from L_input - 2 down to l=1 - see program code below.
I have spent hours with the debugger and pouring over the code, can't spot the bug or mistake in approach. Help please?
Code:
program LegendreDual
   implicit none
   integer, parameter   ::   rep=60
   integer, parameter   ::   dp = selected_real_kind(15, 307)
   real(kind=dp)     ::   X,P,P_minus,P_plus,saveP
   integer         ::   j, L_input
   character(len=rep )   ::   stars=REPEAT('*',rep)
   !----- header ----
   print *, " "
   print *, 'Program LegendreDual starts'
   print *, stars
   !----- Initialise ----
   print *, " "
   print *,'Enter  l, X (l .LT.  0 to stop)'
   read *, L_input, X
   print *, " "
  while (L_input.GE.0) do
       print 20, 'L input','X Input','P'
     If (L_input.EQ.0) then
     P=0
  else if (L_input.EQ.1) then
       P=X
  else
     P_minus=1
  P=X
  Do j=1, L_input-1,+1           ! loop for fwd recursion
     P_plus=(((2*j)+1)*X*P)-(j*P_minus)
     P_plus=P_plus/(j+1)
         saveP=P
     P_minus=P                 ! roll values
     P=P_plus
       end do
     Print 50, L_input, X, P
  P=saveP                   ! P from fwd; we can use P_plus and P
!-----------------------               ! to start the backward recursion
      Do j=L_input-2,1,-1               ! loop for reverse recursion,
     P_minus=(((2*j)+1)*X*P)-((j+1)*P_plus)   ! using P(n+1) and P just found
     P_minus=P_minus/j
     P=P_minus                   ! roll values
     P_plus=P
       end do
  end if
  Print 50, j, X, P             ! only print once if l=0 or 1
     print *, stars
     print *, " "
     read *, L_input, X
  end do
   print *, " "
!--- admin ----
   print *, 'User selected end'
   print *, stars
20   format (3X, A, 3X, A, 18X,A)
50   format (3X, I3, 5X, F10.5, 5X, F25.5)
end program LegendreDual
Please feel free to close or delete this thread and sorry for any inconvenience
