Lens: object distance vs. image distance?
  • Thread starter Thread starter Seadragon
    Image Lens
The discussion centers on the relationship between object distance (s) and image distance (s') in thin lenses, utilizing the thin lens equation 1/s + 1/s' = 1/f. Participants clarify that for a converging lens, both focal length (f) and image distance (s') are positive, while for a diverging lens, they are negative. The graph of s' versus s varies based on the lens type, with specific behaviors noted as the object moves closer or further from the lens. The conversation emphasizes the importance of understanding these distinctions for accurate graphing and interpretation of lens behavior.
  • Understanding of the thin lens equation (1/s + 1/s' = 1/f).
  • Knowledge of the characteristics of converging and diverging lenses.
  • Familiarity with graphing functions and interpreting their behavior.
  • Basic principles of optics related to image formation.
  • Explore the derivation of the thin lens equation in detail.
  • Learn how to graph the relationships for both converging and diverging lenses.
  • Investigate the physical implications of positive and negative focal lengths.
  • Study real-world applications of lens systems in optical devices.
Students studying optics, physics educators, and anyone interested in understanding the principles of lens behavior and image formation.
Seadragon
An object is at distance s from a thin glass lens of focal length f. The lens is surrounded
by air. The image is at distance s' from the lens. Draw a graph of s' versus s. Explain
physically why the graph varies as it does.
I think I am supposed to use the thin lens equation of 1/s+1/s'=1/f.
For a fixed focal length, an increase in s causes the linearly proportional decrease in s'? As an object is moved farther away from the lens, the image also moves farther away.
I don't understand how this equation is independent from the case of a convex or concave lens.
Thanks for any help!
What is the difference in f for a convex versus concave lens?
Can you show us your graph?
A diverging lens has a negative focal length and a virtual image. So f and s' are negative.
A converging lens has a positive focal length and a real image. So f and s' are positive.
1/s + 1/s' = 1/f.
Let's say s is the independent variable on my graph:
For a converging lens:
1/s + 1/s' = 1/f
1/s = 1/f - 1/s'
s = (1/f - 1/s')^-1
For a diverging lens:
1/s - 1/s' = -1/f
1/s = 1/s' - 1/f
s = (1/s'-1/f)^-1. I get a different answer for either converging or diverging =(. I think the question suggests that it shouldn't make a difference whether converging or diverging.
I have no idea how I would graph:
y = (1/x - c)^-1 Well, I guess if I say that 1/f=0 then the graph is y=x. But 1/f doesn't equal zero because if it did, there would be no lens.
Am I on the right track?
1/s + 1/s' = 1/f.
1/s + 1/s' = 1/f
1/s = 1/f - 1/s'
s = (1/f - 1/s')^-1
1/s - 1/s' = -1/f
1/s = 1/s' - 1/f
s = (1/s'-1/f)^-1.
y = (1/x - c)^-1
The easiest way to start with the graph is to just graph a few points for each lens system. Start with the converging lens system, and start with the Object at infinity to the left. Where is the image? Now move the Object into 2*f distance to the left. Where is the Image now? And what happens when you move the Object inside 1*f to the left of the lens?
And do the same thing for the diverging lens. Do the graphs match the equations you've written?
http://en.wikipedia.org/wiki/Lens_equation#Lensmaker.27s_equation
