Leverage and Forces on a Pivot System
The discussion revolves around a lever system with a pivot point, focusing on the dimensions and forces involved in determining the necessary length of the lever to compress an upward force. Participants explore the implications of varying angles as the lever is manipulated, seeking to understand how these factors affect calculations related to force and mechanical advantage.
  • One participant describes a lever system with fixed and variable dimensions, expressing uncertainty about how to calculate the length needed to compress an upward force due to the lever's varying angle.
  • Another participant points out a potential contradiction regarding the dimensions and verticality of the components involved, questioning whether certain points are fixed or variable.
  • Some participants clarify that while the pivot point allows for movement, the vertical component remains fixed in length, leading to discussions about the implications of this on the system's mechanics.
  • There are varying interpretations of how the angle of the lever affects the forces at play, with some suggesting that the angle does not significantly alter the mechanical advantage, while others argue it must be considered in calculations.
  • One participant proposes a method for calculating forces based on moments about the pivot point, providing an example to illustrate the concept.
  • Concerns are raised about the practical implications of human interaction with the lever and how this might affect the calculated mechanical advantage.
  • Several participants express confusion about how to incorporate the varying angle into their equations, indicating a need for further clarification on the principles of moments and lever mechanics.
Participants do not reach a consensus on whether the angle of the lever should be incorporated into calculations, with multiple competing views on the implications of the angle and the fixed nature of certain components. The discussion remains unresolved regarding the best approach to take in the calculations.
Participants highlight limitations in their understanding of the mechanism, particularly regarding the assumptions about fixed points and the behavior of the lever at different angles. There is also acknowledgment that calculations may be approximate due to the variability in the properties of the materials involved.
Saints-94
The diagram drawn below shows a lever system fixed to a point on the left with a pivot point (circle) on the line which attaches to vertical line. I have dimensions for Y and Z and the forces pulling the lever down on the right, and the force acting upwards from below. I am trying to work out the dimension for X to determine how long the lever needs to be to compress the upwards force, but I am unsure due to the varying angle as the lever is pulled down. Any help is greatly appreciated.
Before lever is pulled down.
After lever is pulled down.
Thanks.
Hi Saints,
I sense some contradiction between the Y (FIxed Dim) and the Z piece seemingly staying vertical. Y is clearly shorter in the lower picture. Is the point where XY touches Z fixed on XY (and X also a 'Fixed Dim') or not ?
Y is a fixed dim (may not be to scale on the image). The point on the left of line Y is fixed, and the point where XY touches Z is fixed. However, X is a variable dim as I am trying to work out the length of leverage required to compress the force acting up.
I hope this clears it up a bit better.
Thanks.
Point on the left of Y is fixed. Y is a fixed dim ##\Rightarrow## point where XY touches describes a circle when the 'varying angle' varies. Correct ?
Yes. The angle varies when the lever is pulled down, as Z always stays vertical. The circle represents a pivot point.
You miss my point. The x coordinate of the pivot point moves in a circle, so Z can not stay vertical
I understand the point moves in a circle, however, where Z touches XY it is a pivot point. The pivot allows Z to stay vertical as it moves around the red circle marked on.
Let me try again. In the left picture the arm is at 45 degrees, in the right it is horizontal. Do you see the distance between the left fixed point and the vertical Z has changed ? So either the leeft fixed point has moved to the left or Z has moved to the right and down.
I can see that the length of the arrows have changed as the lever moves down. However, the Y dimension has not changed- the length of the yellow line has stayed the same. From my understanding the pivot allows Z to stay at the same length and vertical, and also allows Y to stay at a fixed length?
The point on the left is always fixed.
Has anyone got any other suggestions as to how this would be solved? Thanks.
The problem as stated can only be solved for the case where the lever almost doesn't move . Applying down pressure on the lever end can then apply down force on the column without the point of contact moving significantly .
I'm struggling to work out what the equation would be. I want to find out the minimum length X would have to be to move the lever down, with a specified force pulling the lever down.
For what you describe - and assuming the small movement idea is ok - and if the 'variable angle' shown in your diagram is set to be somewhere near 90 degrees - the essential mechanism is just that of a simple lever .
Solution can be obtained by taking moments about the fixed pivot point at left end of lever .
Force down on column multiplied by distance Y = Force on end of lever multiplied by distance ( X + Y )
Example :
X = 2 metre , Y = 1 metre and force on end of lever = 100 N
Force on column * 1 = 100 * ( 2 +1 ) . Therefore force on column = 300 N
Thanks for your help.
However, the varying angle can be between 45 and 90 degrees. Does that have an affect on the force on the Z column? And also does the length of Z change the force created?
I am struggling now . Perhaps we have to define the mechanism more clearly .
When you say variable angle do you mean :
(a) that the lever has to swing through that angle when the force is applied ?
or
(b) that the lever could be preset to different angles but doesn't then swing significantly when force is applied ?
The column Z has to stay horizontal when the lever is pulled down. Therefore when the lever is up the angle will be aprrox. 45 degrees, and once its been pulled down it will end up at approx. 90 degrees.
The mechanism is waste compactor, similar to the one below.
So the vertical link is not actually fixed in position after all . Mystery solved .
For the lever being horizontal the calculation in #14 is still ok .
You could do a calculation for the lever at other angles but since the reaction force from squashing the waste is least when the lever is 45 deg up and greatest when it is somewhere near horizontal I think you could just use that one answer for horizontal for design purposes .
Any calculations are going to be approximate anyway due to the varying properties of waste material .
That's great. So as the force will be greatest at 90 degrees I can assume that it would be worst case?
Yes, they will be approximate. I have done some testing to get an approximate force required to compact household waste.
Yes - I think you'd be quite safe to use lever being horizontal as worst case .
Okay, thanks. If I were to do a calculation for the lever when it is at 45 degrees, how would I incorporate the angle into the equation?
You should be careful here. The ratio of the two (parallel) vertical forces is the same for all angles of the arm - if the system really can be treated as implied in the diagrams at the top of the thread. So the Mechanical Advantage (or at least the Velocity Ratio) will be independent of angle.
The two vertical forces will always be the same.
So does the angle need to be taken into consideration in the equation or not?
Thanks.
In practice there are two problems :
(a) Human operators tend to push or pull on long levers in a direction at right angles to the lever rather than just always straight downwards ,
(b) The drop link may swing from being vertical to an inclined position .
(a) and/or (b) can alter the calculated mechanical advantage figure considerably .
If working with all known quantities an exact calculation might be useful but in this case probably not worth the trouble .
(a)The lever will be pulled down from overhead, I can't see how that will affect the calculation? (b)Also I am making an assumption that the 'drop link' will stay vertical for the purpose of the equation.
Going back to the formula discussed previously, is there a way to incorporate the change in the 'varying angle', or is it not necessary?
Have you done any reading around levers and moments? The principle of moments uses the phrase 'perpendicular distance' in the definition of the moment of a force around a fulcrum. This link gives you a way into the topic if you haven't already read about it. The simple, lower school, treatment of moments is only restricted to horizontal levers / see-saws etc. but the angle is important if you want to understand it more fully.
I have done some work on moments previously.
I understand that when the line is at 90 degrees: Force on the vertical line multiplied by Y = Force on end of lever multiplied by ( X + Y )
However, when the lever is at 45 degrees I am struggling to create a formula that incorporates the angle.
Why do you need to "create" one? It's in any A level textbook and many other places. Try the link I gave you
You don't have to invent Physics all your own.
Sorry, maybe 'create' was the wrong terminology.
I am trying to write out the formula that incorporates the angle.
For the two instances - line at 45 and 90 degrees- I have written the formulas below.
When the line is at 90 degrees: Force on the vertical line multiplied by Y = Force on end of lever multiplied by ( X + Y )
When the line is at 45 degrees: Force on the vertical line (sin45) multiplied by Y = Force on end of lever multiplied by ( X + Y )
Are these correct?
For good reasons: the handlebar is also constrained to move along an arc with radius X+Y. I don't think a component along the X Y arm is doing anything useful -- anyone ?
So I drew ##F_1## as Nidum suggests
Moment balance: $$F_1 \times (X+Y) = F_2 \times X$$
Decomposition of ##F_2##: $$F_{2,\rm v} = F_2 \sin 45^\circ$$
So your formula should be $$F_{2,\rm v} = F_1 {X+Y\over X} \sin 45^\circ$$
Again, if Z starts moving, the top is constrained to move along the dashed arc, but that shouldn't be a big issue: let go, press again is the recipe.
I do see trouble for big strong guys: they can easily compress the stuff so tightly that it doesn't come out any more when the bin is collected...
  • · Replies 52 ·
  • · Replies 21 ·
