L'Hopital's Rule: 0/0 Indeterminate Limit
  • Thread starter Thread starter Hernaner28
9 replies · 3K views · last reply
Hernaner28
This is just a question. We have:
[tex]\mathop {\lim }\limits_{x\to 0} \frac{{{x^2}\sin \frac{1}{x}}}{x}[/tex]
Which is indeterminate of type 0/0 but we can apply L'Hopitale. Well, in fact we could (and must) cross out the x to solve the limit but let's assume that we forgot to do that and we derivate it so we get:
[tex]\mathop {\lim }\limits_{x\to 0} \frac{{2x\sin \frac{1}{x}-\cos \frac{1}{x}}}{1}[/tex]
And the limit doesn't exist! Why is not L'Hopitale applicable in this case not crossing out the x's?
Thanks!
Because the derivative of the numerator doesn't have a limit as x->0. The function has a limit but not the derivative. The rule does not apply if the limits of the derivatives don't exist.
Hmm, well you know you can cancel the x to get: $$x \sin{\frac{1}{x}}.$$ From here it is just the sandwich theorem, we know $$ -1 \leq \sin{\frac{1}{x}} \leq 1 $$ so then $$\lim \limits_{x \to 0} -x \leq \lim \limits_{x \to 0} x \sin{\frac{1}{x}} \leq \lim \limits_{x \to 0} x$$
And you can take it from here.
Thanks!
What you did wrong is doing a terrible job of differentiating the numerator. You have to use the chain rule.
No, I think the OP is correct, after simplification. (At a glance, I also thought they were wrong...but actually not).
It seemed to me the OP already knew this and referred to it. The question was why L'Hospital didn't work.
Right you are.
Thanks!
L'hopital's rule says that whenever you have two functions f and g that each converge to zero, that if lim f'/g' exists, then lim f/g exists and the two limits are equal. It does not say that if lim f/g exists then lim f'/g' exists -- as you can see from your own example, it is entirely possible that the original limit exists and the limit of the derivatives does not.
This is what I wanted to know. So then, how can I realize that f'/g' doesn't exist but f/g does (let's keep assuming I forgot to cancel the x)?
THanks!
Unfortunately I can think of no simpler way to recognize this situation than to try to compute the limit of f'/g' directly, thus showing it doesn't exist, and then to use some alternate method (such as cancelling the x and applying the squeeze theorem) to show that the limit of f/g does.
