Lifting vs Pulling: Chain Hoist vs Hand Winch
  • Level: High School
  • Thread starter Thread starter Gsu student
    Lifting
3 replies · 27K views · last reply
Gsu student
Ok so I was at the store today and I notised that the hoist they sell seam to be a lot beefyer and stronger lookin them the come a longs ie hand winches and I was wondering why that was dose it take more force to lift 2 ton then it takes to pull the same, I was looking at a 1 ton chain hoist and it's all steel and thick chain looks real strong yet right next to it is a 4 ton puller made from thin steal and wire rope, now granted the puller dose use a pullie but that dosent change the fact that the force on the unit is still greater
if anyone can help please let me know. Would a chain hoist pull more that a similar rated hand winch?
Force required to lift has to overcome gravity
F = mass* gravity
Force required to pull has to overcome friction.
Friction Force = Force from gravity * Friction coefficient.
Friction fore is much smaller then gravitational force, as coefficients of friction are much less then 1 usually.
Yes it's a question of force.
If you lift a 1 ton object you need a force of 1000kg * 9.8m'/s^2 (ie g) = 9800N
To pull the same object would depend on the friction between the object and the surface, for steel wheels on a steel rail (such as a railway car) the friction would be about 0.1% so you only have to pull with a force of 9.8N, equal to lifting only a 1kg.
For very low friction like oil bearings it's possible to push huge masses, like a 100ton telescope, with almost a finger tip.
If the chain hoist and the come-a-long have the same SWL (safe working load) of 2 tons (or whatever), then they can pull or lift the same amount. The position is irrelevant. I can take a come-a-long (puller) rated for 2 tons (SWL) and use it vertically to lift 2 tons.
What you are probably noting is that most come-a-longs have typically lower SWL's than do chain hoist for the reasons stated above.
CS
