Light Refraction: Direction of Bend
6 replies · 12K views
mmg0789
For each of the following cases, will the light rays be bent toward or away from the normal?
a. ni > nr, where the angle of ni = 20
b. ni < nr, where the angle of ni = 20
c. from air to glass with an angle of incidence of 30
d. from glass to air with an angle of incidence of 30
for a, i put toward. b i think is away (but I'm not sure why it would be) and i am not sure about c and d
thanks in advance
You are correct for a and b. Perhaps if you drew a diagram, it would make the answer more apparent. Where are the angles measured from?
As for c and d. Consider snell's law, what happens when a light ray travels through the interface from a lower refractive index (air) to a higher (glass) and visa versa.
~H
well i think this is a conceptual problem, so no equation is needed. but the equation i have to work with is (ni)(sinXi)=(nr)(sinXr)
--index of refraction of first medium x sine of the angle of incidence = index of refraction of second medium x sine sine of the angle of refraction
I find that that looking at a physics problem from different perspectives is often useful. As Hootenanny has indicated, diagrams here are very useful, but I like also to verfiy things with mathematics.
Note that the graph of sinx is increasing for x between 0 and 90, i.e., if sinx2 > sinx1, then x2 is greater than x1.
Now consider a) ni > nr. In order for ni sinXi = nr sinXr to hold, this means that sinXi < Sin Xr, which in turn, from what I wrote above, means that Xi < Xr. Now, a diagram shows what happens with respect to bending towards/ away from the normal.
Regards,
George
