Lightning rod/cable to protect tent
  • Thread starter Thread starter dj1990
    Lightning
12 replies · 4K views
dj1990
Hi all,
I'm due to go camping with someone who is very scared of getting fried by a lightning bolt.
The poles on our tent are heavy(ish) metal ones, presumably steel, and I'm guessing would not be thick enough to make it a Faraday cage?
I had the idea of running a cable from a rod at the top point, running it down one of the poles and attaching it to another rod that sticks in the ground.
First of all, is this a good idea? Secondly, is anyone able to estimate what kind of thickness copper cable would be required?
Thanks in advance!
Will you be near a car or are you back country camping.?
Ugh. Lightning and lightning protection are some of the least predictable controversial subjects.I like this advice from the article @berkeman linked.
  • Avoid open fields, the top of a hill or a ridge top.
  • Stay away from tall, isolated trees or other tall objects. If you are in a forest, stay near a lower stand of trees.
  • If you are camping in an open area, set up camp in a valley, ravine or other low area.
  • Stay away from water, wet items (such as ropes) and metal objects (such as fences and poles). Water and metal are excellent conductors of electricity. The current from a lightning flash will easily travel for long distances.
Those things are more reliable than homemade lightning rods.
But the sad news is that all your remedies are unlikely to quell the fears of your friend.
And if maybe you will be playing volleyball in camp with several of your friends and you notice that there are thunderstorms approaching in the distance, it is best to call off the game early, and not wait. Please do not ask me how I know this...
Looking up to bump the volleyball for my spiker, and the lightning hit something so close that there was no delay between the light flash and the super loud boom. The lightning strike probably hit our vball standards. Duck for cover and run!
Your friend's fear is real, but almost certainly misplaced. There are many more significant dangers associated with camping, travelling, or staying at home.
A metal tent pole is safer than an insulated pole. Just don't hold onto the pole while there is a local thunderstorm.
Where you pitch your tent will be more important than grounding the pole or the occupants. Pitch the tent one tree-height away from trees that could fall. Those trees will attract the lightning and protect your tent. Avoid pitching the tent on a ridgeline, or where it could be exposed to a lot of wind.
You might be able to use placebo wire to reassure your friend. Connect it from the metal tent pole to the ground away from the tent.
  • Haha
  • Love
Even if the poles would be able to arrest a lightning, step voltage would almost certainly fry you unless you put some wires/rods below the tent too
If that fear is so intensive, then do van camping. That'll protect against falling trees too.
This would be more effective if bought from a store. Is there a fortune to be made here?
Actually we get a few storms per season here in Indiana where it would be unfortunate to be outside unprotected
Kind of like this? :wink:
https://arbusa.com/tents-awnings-camping/rooftop-tents/simpson-iii-rooftop-tent/
  • Haha
For a small building, the idea, from a old British Standard is to have raised metal poles with a ridge wire. Then we take conductors sloping down to the ground. The outside of the tent is surrounded by a peripheral bare wire on the ground which is intended to create equi-potential conditions. One of the problems with lightning protection is that ground currents will kill. That is why cows are killed near a ground strike. It is very difficult to obtain a low ground electrode resistance with a temporary structure like this. The conductors are 50mm2 copper.
In my opinion, it would be a bad experience to be a few feet from a lightning strike due to the light, shock wave and noise. I don't think lightning protection of a tent is very practical. I have a similar problem in a small boat, but at least I can obtain a good ground connection.
Not from the sizes of trees and branches where I camp. They could squash a van pretty flat.
Edit: I just remembered a camping trip from 2017. The national parks permanently closed all camp sites located under cottonwood trees. They could be made safe by cutting the trees down, but then they would have no shade.
