Limit of a trigonometric function (Involved problem)
The limit of the trigonometric function \(\lim_{x\to 0}\frac{\sec \frac{x}{2}-1}{x\sin x}\) was evaluated using algebraic manipulation and the conjugate method, both of which initially resulted in indeterminate forms. The first approach involved rewriting the expression to isolate \(\frac{1 - \cos \frac{x}{2}}{x \sin x \cos \frac{x}{2}}\) and applying the limit properties. The second approach transformed the limit into terms of sine, allowing the use of the \(\frac{\sin x}{x}\) limit. Ultimately, the limit was successfully evaluated, confirming the effectiveness of these methods.
vertciel
Evaluate \underset{x\to 0}{\mathop{\lim }}\,\frac{\sec \frac{x}{2}-1}{x\sin x}, WITHOUT using l'Hôpital's rule.
Hello there,
I tried to evaluate this limit using two different approaches, both of which still leave the limit in indeterminate form when 0 is substituted.
Thank you for your help!
I) Pure algebraic manipulation:
\begin{align}<br /> &amp; \underset{x\to 0}{\mathop{\lim }}\,\frac{\sec \tfrac{x}{2}-1}{x\sin x}=\underset{x\to 0}{\mathop{\lim }}\,\left( \frac{1-\cos \tfrac{x}{2}}{\cos \tfrac{x}{2}}\div \frac{1}{x\sin x} \right)=\underset{x\to 0}{\mathop{\lim }}\,\left( \frac{1-\cos \tfrac{x}{2}}{x\sin x\cos \tfrac{x}{2}} \right) \\ <br /> &amp; =\underset{x\to 0}{\mathop{\lim }}\,\left( \frac{1-\cos \tfrac{x}{2}}{\tfrac{x}{2}} \right)\times \underset{x\to 0}{\mathop{\lim }}\,\left( \frac{\tfrac{1}{2}}{\sin x\cos \tfrac{x}{2}} \right) \\ <br /> \end{align}
II) Manipulation with conjugate method:
\begin{align}<br /> &amp; \underset{x\to 0}{\mathop{\lim }}\,\frac{\sec \tfrac{x}{2}-1}{x\sin x}=\underset{x\to 0}{\mathop{\lim }}\,\left( \frac{1-\cos \tfrac{x}{2}}{x\sin x\cos \tfrac{x}{2}} \right) \\ <br /> &amp; \text{Let u = }\tfrac{x}{2}.\text{ Since }\underset{u\to 0}{\mathop{\lim }}\,u=0\text{, u still tends to 0}\text{.} \\ <br /> &amp; \underset{u\to 0}{\mathop{\lim }}\,\frac{1-\cos u}{\tfrac{u}{2}\cos u\sin \tfrac{u}{2}}\left( \frac{1+\cos u}{1+\cos u} \right)=\underset{u\to 0}{\mathop{\lim }}\,\frac{1-{{\cos }^{2}}u}{\tfrac{u}{2}\cos u\sin \tfrac{u}{2}(1+\cos u)} \\ <br /> &amp; =\underset{u\to 0}{\mathop{\lim }}\,\frac{{{\sin }^{2}}u}{\tfrac{u}{2}\cos u\sin \tfrac{u}{2}(1+\cos u)} \\ <br /> \end{align}
One way to approach this problem is to transform everything into sine. Then, you can make use of the sin(x)/x limit. To transform the difference 1 - cos(x/2) into a sine, for example, substitute cos(0) for 1 and make use of the sum to product formulas, or recognize it as part of a power reducing formula for sine.
First let u=x/2, then x=2u. As x/2→0, u→0 also.
\lim_{x\rightarrow 0}\frac{\sec\frac{x}{2} -1}{x\sin x} = \lim_{u\rightarrow 0}\frac{\sec u - 1}{2u\sin2u} \times \frac{\sec u + 1}{\sec u + 1} = \lim_{u\rightarrow 0}\frac{\sec^2u - 1}{2u\times 2\sin u \cos u(\sec u + 1)}
The numerator becomes tan2u, then see where you can go from there.
Thank you very much for your replies, Tedjn and Bohrok.
I was able to evaluate this limit.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 40 ·
