Limit of Absolute Values: Understanding the Concept
The discussion revolves around evaluating the limit of a function involving absolute values as x approaches 3 from the left. The specific expression under consideration is (3x-9)/|3x-9|.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants explore the behavior of the expression |3x-9| for values of x less than 3 and discuss its implications for the limit. There are attempts to clarify the sign of the expression and its impact on the limit evaluation.
Participants are actively engaging with the problem, questioning assumptions about the signs of the expressions involved. Some suggest alternative approaches, such as substitution, while others emphasize direct evaluation of the limit. There is a recognition of the complexity of the limit as it approaches an indeterminate form.
Some participants note constraints related to the teaching context, such as the lack of familiarity with L'Hôpital's rule, which influences their approach to the problem.
azncocoluver
http://www4c.wolframalpha.com/Calculate/MSP/MSP621a026b7befdf1f1d00003b707661e1i20i4e?MSPStoreType=image/gif&s=55&w=126&h=38
limit x->3- (3x-9)/((abs(3x-9))
I don't understand how to find the limit of absolute values..
what is the sign of |3x-9| for x<3?
It would be -|3x-9| = -3x-9.. right?
the sign is negative - however what you have written is in correct
the way to do it is as follows
x<3
3x<9
3x-9<0
so it is negative, to make positive let's multiply by -1.
So for x<3
|3x-9| = -(3x-9) = 9-3x
however an even simpler way would be to do a subtitution (maybe, depending what you're comfortable with...)
so you could let
[tex]y=3x-9[/tex]
then
[tex]\lim_{x \to 3^-} \ \implies \ \lim_{y \to 0^-}[/tex]
and the limit becomes
[tex]\lim_{x \to 3^-} \frac{3x-9}{|3x-9|} \ \implies \ \lim_{y \to 0^-} \frac{y}{|y|}[/tex]
x<3
3x<9
3x-9<0
So for x<3
Okay so the fraction is now 3x -9 / 9-3x? How do I get the answer of -1 though? Also, is the limit of y/abs(y) is always going to be -1?
1) how would you normally evaluate a limit, or where are you stuck. Is this one indeterminate?
2) No. Maybe from the negative side, but that's what we're trying to show isn't it.
Try out evaluating the direct limit first rather than the substitution, we can come back to that, but it is a helpful comparison
Can you show me the steps to complete this problem because I have no idea where to start.
well let's star my considering the numerator and denominator separately, qualitatively, what happens to each x goes to 3 from the left
the do you know about l'hospital's rule?
We can't use L'Hopital's rule yet because my teacher hasn't taught it. Um, the numerator goes to infinity and so does the denominator. So infinity/infinity?
not quite, have another think, what happens to 3x-9 when x->3
now this doesn't really need L'Hop as we have
[tex]\lim_{x \to 3^-} \frac{3x-9}{|3x-9|} = \lim_{x \to 3^-} - \frac{3x-9}{3x-9}= - (\lim_{x \to 3^-} \frac{3x-9}{3x-9})[/tex]
as they're identical, i don't think it s a leap to say the final limit is -1
Oh okay I think I finally understand. 3x-9 / 3x-9 is 1 and since there is a negative outside the parantheses, the limit is just -1 because you can't plug 3 into x since there is no x left.
