MHB What is the limit of (sqrt(1+x)-sqrt(1-x))/x as x approaches 0?
  • Thread starter Thread starter theakdad
    Function Limit
The limit of (sqrt(1+x)-sqrt(1-x))/x as x approaches 0 results in the indeterminate form 0/0. To resolve this, multiplying by the conjugate of the numerator, which is (sqrt(1+x)+sqrt(1-x)), is recommended. This manipulation simplifies the expression, allowing the x in the denominator to be eliminated. After simplification, the limit can be evaluated by dividing the numerator and denominator by x. The final approach leads to a clearer calculation of the limit.
theakdad
I know i asked similar questions multiple times,but again i have a problem,seems I am not good with roots...
I have to calculate the following limit:
$$\lim_{x \to 0} \frac{\sqrt{1+x}-\sqrt{1-x}}{x}$$
Mathematics news on Phys.org
What do you get if you try substituting $x=0$ into the expression?
I get $0$ of course...so i know i should do some operations,so i get rid of the x in the denumerator.
You actually get $$\frac{0}{0}$$, and this is a dreaded indeterminate form. So, since you have seen problems like this before, what would you say we need to do to get it into a determinate form? What would be a good strategy?
maybe to move the roots somehow into the denumerator?
Correct, and how can we accomplish this?
To multiply with $$\sqrt{1+x}-\sqrt{1-x}$$ ?
No, you want to use the conjugate of the numerator, this way the radicals will disappear from the numerator.
How?
wishmaster said:
How?
What is the conjugate of the numerator?
$$1-x$$ ??
Im stupid it seems...
wishmaster said:
$$1-x$$ ??
Hey, don't get discouraged...you are learning...it takes time. :D
Consider the expression $a+b$. It's conjugate is $a-b$. Do you see that if we multiply them together, we will have a difference of squares, and a squared radical is no loger a radical. So now what would you say the conjugate of the numerator is?
$$\sqrt{1+x}+\sqrt{1-x}$$ ?
Yes, good! :D
Now, you want to multiply the expression for which you are asked to find the limit by $1$ in the form of this conjugate divided by itself:
$$1=\frac{\sqrt{1+x}+\sqrt{1-x}}{\sqrt{1+x}+\sqrt{1-x}}$$
What do you find?
MarkFL said:
Yes, good! :D
What do you find?
But how turned the denumerator into this term? I had $x$ in it.
This is what you want to multiply the expression with. Since it is $1$, you aren't changing its value. So you want:
$$\lim_{x \to 0} \frac{\sqrt{1+x}-\sqrt{1-x}}{x}\cdot\frac{\sqrt{1+x}+\sqrt{1-x}}{\sqrt{1+x}+\sqrt{1-x}}$$
So i multiply all together?
Yes. You will find you will be able to get rid of the $x$ in the denominator as well when you reduce.
$$\frac{2x}{x(\sqrt{1+x}+\sqrt{1-x})}$$ ?
Hello wishmaster!
I bet it's mather of time until you learn l'hopitals rule which i would use when I see this limit :P here you got a Link that explain it well Pauls Online Notes : Calculus I - L'Hospital's Rule and Indeterminate Forms
Ofc MHB Will help you if you need help understanding it:)
Have a nice weekend!:)
Regards,
$$|\pi\rangle$$
- - - Updated - - -
Divide top and bottom with x and Then calculate the limit! Good job!:)
