Limit of (-x^(k+1))/e^x: Solving Step by Step with l'Hopital's Rule
  • Thread starter Thread starter ckyborg4
    Figure Limit
The discussion revolves around finding the limit of the expression (-x^(k+1))/e^x as x approaches infinity. The subject area includes limits and the application of l'Hôpital's Rule, particularly in the context of polynomial and exponential functions.
  • Participants discuss the application of l'Hôpital's Rule multiple times, noting that the degree of the polynomial in the numerator decreases while the exponential in the denominator remains. Some express uncertainty about how to handle the variable degree of the polynomial.
There is ongoing exploration of the limit, with some participants suggesting that applying l'Hôpital's Rule k + 1 times is necessary to reach a constant in the numerator. Others propose using the squeeze theorem as an alternative approach, indicating a productive direction in the discussion.
Some participants question the assumptions regarding the behavior of the polynomial and exponential functions as x approaches infinity, particularly in relation to the degree of the polynomial being treated as a variable constant.
ckyborg4
I'm trying to do this limit based on a previous thread ( https://www.physicsforums.com/threads/proving-n-x-n-e-x-integrated-from-0-to-infinity.641947/#_=_ )
I got up to the last part of thread where I need to find the limit of:
limit as x approaches infinity of: (-x^(k+1))/e^x
I know that this limit somehow must equal to zero in order to get the right answer, but I did l'Hopital's rule 4 times and it just keeps on going to infinity.
I attached the working out of the whole problem
Really appreciate it if someone could help
If you keep using L'Hospitals rule with a polynomial in the numerator and an exponential in the denominator, the numerator's degree will eventually become 0 while the exponential remains in the denominator.
I can't seem to get it to work here because the exponent of the polynomail has a degree k. If the degree of the polynomail is a variable constant I am not sure how i can get it to zero
What's the derivative of any constant?
Keep going. You must apply l'Hopital [itex]k + 1[/itex] times in total before you get a constant in the numerator.
Alternatively, as every term in the series [itex]e^x = \sum_{n=0}^\infty \frac{x^n}{n!}[/itex] is strictly positive when [itex]x > 0[/itex], we have [itex]e^x > \frac{x^{k+2}}{(k+2)!}[/itex] and hence [tex]0 < \frac{x^{k+1}}{e^x} < \frac{(k+2)!x^{k+1}}{x^{k+2}} = \frac{(k+2)!}{x}.[/tex] Now use the squeeze theorem.
This is how I'd do it, as I tend to think l'Hopital is a rather unintuitive power-tool that should be used as a last resort.
At a minimum, I'd change it to
##0 \leq \frac{x^{k+1}}{e^x} \leq ...##
though, otherwise that strict inequality would seem to cause problems, as in the limit we have ## 0 \lt 0##
  • · Replies 23 ·
  • · Replies 21 ·
