Limit problem simplify the root
9 replies · 2K views
StrSpeed
[/B]
I feel like I'm missing some theorem which is preventing me from finalizing this problem! It's been driving me nuts I feel like I'm missing something super basic!
Ultimately they've given the solution, g/8, so I know this is how I should try to get the equation to look algebraically. But, no matter how I manipulate it I can't get it to reduce.
I feel like this has to do with √x2 = |x| Which then depending on your value of x will give x, or -x. However, I can't simplify the root into a way which will let me make this jump.
https://www.desmos.com/calculator/hf8poewlvb
(link to all my reductions)
Try multiplying numerator and denominator by$$
c\sqrt{\left(\frac{c^2}{g^2}+\frac 1 4\right)}+\frac{c^2}{g}$$
The conjugate! How could I forget that.. Thank you! Now I have:
PS. g is not squared I wrote it down wrong.
Let me see what more I can do.
Alternatively: You can take a common factor out of the expression under the square root to obtain [tex] h(c) = A\sqrt{1 + x} - \frac{c^2}{g}[/tex] where [itex]x < 1[/itex] for sufficiently large [itex]c[/itex]. Hence you may expand the root as a binomial series, [tex] (1 + x)^{\alpha} = 1 + \alpha x + \frac{\alpha(\alpha - 1)}{2!}x^2 + \dots[/tex]
Thanks for both of your help! Still working on it, sadly.. I pulled out a C so I'm left with:
https://www.physicsforums.com/file:///C:/Users/Steven/Downloads/CodeCogsEqn.gif
Im not entirely sure what I could pull out of the root.
Factor out the c you'll have 1/4 * (lim c ->0 1/(sqrt(1/g^2 + 1/4c) + 1/g) and don't forget that 1/4c goes to 0 whenever c -> 0, good luck
That's good.
##\displaystyle \ \frac14\lim_{c\to\infty}\left(\frac{c^2}{\displaystyle c\sqrt{\left(\frac{c^2}{g^2}+\frac 1 4\right)}+\frac{c^2}{g}}\right)\ ##
One way to deal with rational expressions where some factor →∞ : divide the numerator and denominator by the highest power of that factor.
Divide by c2 in the numerator & denominator.
I got it! You guys rock thank you so much! Once I got down to that last x Term I realized that a constant/infinity = 0!
Here is my work through!
You should drop the limit sign from the second last row.
At the point highlighted above, simply take the limit and simplify.
