Undergrad Limit with integral and absolute value
The discussion revolves around solving an integral, specifically the antiderivative [x + sin(x) - 1]. Participants clarify that "sen" is an abbreviation for sine and discuss the evaluation of the integral from 0 to x. A key point raised is the limit of sin(x)/x as x approaches 0, which is essential for simplifying the expression. The conversation also touches on the behavior of sin(x) and x near zero, emphasizing that they are approximately equal in that range. Overall, the thread highlights the importance of understanding limits and the behavior of functions around critical points in calculus.
Genilson
Hello good evening to all, I was studying here and got stuck with this.
I solved the integral and got [x+sin(x) -1]
and that´s the farthest that I got. I would appreciate the help.
Can you explain, what ##sen## means and where the ##1## in your antiderivative comes from?
Likes Genilson
fresh_42 said:
Can you explain, what sen means
I believe it is another abbreviation for sine.
Likes Genilson
yep , sorry (sen) = (sin).
Ok, the antiderivative should be
[ t + sin(t) ] from 0 to x.
Then I get [ x + sin(x) - 0 - sin(0) ] and Yep, I found my first mistake. sin(0) = 0
Btw I would like a solution without using L' Hopital rule, if there is one of course.
Are you allowed to use ##\lim_{x \rightarrow 0}\frac{\sin (x)}{x}=1##? If so, you could cancel the quotient by an ##x##.
Likes Genilson
Yep, I can use sinx/x limit but it still leave me with 0 in the denominator
And a ##2## in the nominator, which tells you?
Edit: Or more directly: What happens, if you divide a real number by a number that gets closer and closer to zero?
Likes Genilson
it goes to + infinite, but Wolfram gives me as answer +inf and - inf.
You'd probably ignored the absolute value of your denominator. How do you manage to get a negative number?
Likes Genilson
I have 1 + sinx/x in the numerator, so, they´re supposed to tend to zero isn´t it? from the left or from the right it will return me 0, or am I wrong?
##\sin x## and ##x## are pretty much the same in a small neighborhood around zero, aren't they? This means ##\frac{\sin x}{x} \, \approx \,1##.
If ##x## is negative, then ##\sin x## is as well.
Likes Genilson
I've never seen it this way, thank you very much!
  • · Replies 31 ·
