Limit with integral and absolute value
11 replies · 2K views
Genilson
Hello good evening to all, I was studying here and got stuck with this.
I solved the integral and got [x+sin(x) -1]
and that´s the farthest that I got. I would appreciate the help.
Can you explain, what ##sen## means and where the ##1## in your antiderivative comes from?
yep , sorry (sen) = (sin).
Ok, the antiderivative should be
[ t + sin(t) ] from 0 to x.
Then I get [ x + sin(x) - 0 - sin(0) ] and Yep, I found my first mistake. sin(0) = 0
Btw I would like a solution without using L' Hopital rule, if there is one of course.
Are you allowed to use ##\lim_{x \rightarrow 0}\frac{\sin (x)}{x}=1##? If so, you could cancel the quotient by an ##x##.
Yep, I can use sinx/x limit but it still leave me with 0 in the denominator
And a ##2## in the nominator, which tells you?
Edit: Or more directly: What happens, if you divide a real number by a number that gets closer and closer to zero?
it goes to + infinite, but Wolfram gives me as answer +inf and - inf.
You'd probably ignored the absolute value of your denominator. How do you manage to get a negative number?
I have 1 + sinx/x in the numerator, so, they´re supposed to tend to zero isn´t it? from the left or from the right it will return me 0, or am I wrong?
##\sin x## and ##x## are pretty much the same in a small neighborhood around zero, aren't they? This means ##\frac{\sin x}{x} \, \approx \,1##.
If ##x## is negative, then ##\sin x## is as well.
