Limitations of the Lebesgue Integral
The discussion centers on the limitations of the Lebesgue integral, particularly regarding its ability to handle functions where both the areas above and below the x-axis are infinite, yet their difference is finite. Participants highlight that while the Lebesgue integral is defined for functions where the absolute value is integrable, it fails for certain functions like sin(x)/x over [0, ∞). The conversation also touches on the concept of gauge integration as a potential extension of the Lebesgue integral, which may address some of these limitations. Key references include an Insight article and a recommended textbook on measure theory.
  • Understanding of measure theory concepts
  • Familiarity with Lebesgue and Riemann integrals
  • Knowledge of improper integrals and their properties
  • Basic grasp of functions and their integrability conditions
  • Research gauge integration and its applications
  • Study the properties of Lebesgue integrable functions
  • Explore the differences between Lebesgue and Riemann integrals in depth
  • Examine specific examples of non-Lebesgue-integrable functions
Students and professionals in mathematics, particularly those studying measure theory, integration techniques, and anyone seeking to deepen their understanding of the limitations of the Lebesgue integral.
The_eToThe2iPi
So I'm studying a course on measure theory and we've learned that the Lebesgue integral of a real function is (loosely) defined as the total area over the x-axis minus the total area under the x-axis. This seems to me to be limited because these areas can both be infinite but their difference may be finite (such as sin(x)/x integrated from 0 to +inf) and, for me, this is a major failing for a definition of the integral. I was wondering whether there were any extensions to the Lebesgue integral that can handle these types of functions?
A function ##f(x)## is Lebesgue integrable iff ##|f(x)|## is Lebesgue integrable
Don't you already have that for ordinary Riemann integrals ##\int_0^\infty x\,dx \; , \;\int_1^\infty x\,dx## and their difference? So what's new?
Ahh, that's interesting. I didn't think about that. But I still feel that there is a difference between the two instances. In your case we are evaluating two separate Riemann integrals, finding they are infinite, and then asking what their difference is like asking what is ##(a+\infty) -\infty##. The Lebesgue integral is finding a single integral by separating the function into two parts and, as a result of this, means that certain functions in certain domains are not Lebesgue integrable even though they intuitively should be integrable. Obviously the question of what the "difference" between two infinite values can be stated in terms of Riemann integrals but it is not per say a failing of Riemann integration since the definition does not rely on this.
Also I apologise for the lack of rigour but I'm simply trying to further understand the concepts involved in integration and, whilst I appreciate the necessity for formalism, I'm still kinda a noob at this and trying to formulate every sentence in full rigour is both difficult and not very revealing...
I don't know if this helps, but you can also see the Lebesgue integral as partitioning the range , instead of the domain and finding the sum ( as a limit) ## x *m(f^{-1} (x))## , i.e., the sum of values in the range times the measure of their preimages. It is often put as, if you had 1 nickel ( 5c ) 2 dimes ( 10 c each), 3 quarters (25 c each) , the Riemann sum would be 5 + 10 +10 +25+ 25+ 25, while Lebesgue would do: 5(1)+ 10(2) +25(3) , with 1,2,3, being the (discrete version) of the measure of the preimage of a value.
Well, the Insight article I quoted is a good start and explains what @WWGD just said. In general measure theory can be very abstract (depends on the teacher and/or textbook). Basically the ##"dx"## becomes the subject of consideration and generalization rather than geometric objects. You might remember, that already ##"dx"## had been a generalization from something that started with length times width.
Wow, just imagine if students had to buy all their own textbooks! £152! Fortunately I think the university has a copy of that one so I won't have to sell my kidney :)
The page on gauge integration mentions that this integral can be extended more general domains and I was wondering whether whether these extensions allow integration over domains as general as the Lebesgue Integral. Also are there not a similar examples of more general functions that the Lebesgue integral cannot handle or is it only for real functions that we encounter this problem.
To be honest, I feel like these are the sort of questions that require me to read a book (and I'll probably have even more afterwards). Thank you all so much for answering my questions and pointing me in the right direction.
Anyway, the standard example, in my experience of a non-Lebesgue-Integrable function is ##f(x)= \frac {1}{x} ##
What domain are you integrating ##f(x)=\frac{1}{x}## over? Does an improper Riemann integral exist for ##f(x)=\frac{1}{x}## over that domain? The reason I used ##sin(x)/x## was because it is an alternating function and so needs to be broken down into it's positive and negative parts in order to evaluate the Lebesgue integral and as a result this integral cannot be evaluated (in the Lebesgue sense) over the interval ##[0,\infty)##. I cannot see this same problem with ##f(x)=\frac{1}{x}##...
##(0,1] ## is an example. EDIT Compare, e.g., with ## \int_{1/n}^1 \frac{1}{x} dx ## as lower bounds for the integral over ##(0,1]##.
But doesn't this also not have a Riemann integral over that same domain since ##\int^{1}_{\delta}\frac{1}{x}dx=[ln(x)]^{1}_{\delta}=ln(\frac{1}{\delta})## but ##ln(\frac{1}{\delta}) \to \infty## as ##\delta \to 0##?
Yes, but that is the point; if the Riemann integral exists, then so does the Lebesgue, but in many cases some functions that are not R-integrable are L-integrable, but this one is neither.
16K
