Limiting DC Current for Car Battery Use
The discussion revolves around methods to limit the output current to 20 mA while maintaining a nominal output voltage of 12 volts from a car battery. Participants explore various circuit designs and components that could achieve this goal, considering both theoretical and practical implications.
  • John inquires about limiting the current to 20 mA while keeping the output at 12 volts.
  • Some participants suggest using a fuse as a simple solution, noting that it would blow if the current exceeds 20 mA.
  • Others propose various current limiting circuits and emphasize that exceeding the current limit would result in a voltage drop below 12 volts.
  • One participant mentions the need to calculate a sense resistor value to achieve the desired current limit, providing an example calculation.
  • Concerns are raised about the power ratings of components in the circuit.
  • Questions arise regarding the specific application for the 20 mA limit and the acceptable voltage tolerance for the output.
  • Some participants suggest using a series resistor to achieve the current limit while allowing for a voltage drop.
  • Discussion includes the possibility of using a DC-DC converter for maintaining the output voltage while limiting current.
  • Technical details about automotive regulators and their protective features are mentioned as potential solutions.
Participants express a range of ideas and approaches, with no consensus on a single solution. Multiple competing views on circuit design and component selection remain unresolved.
Participants highlight the importance of understanding the load specifications and the implications of voltage drops on the circuit's functionality. There are mentions of specific component characteristics and the need for further information about the load to refine the proposed solutions.
Individuals interested in electronics, particularly those working with automotive applications or current limiting circuits, may find this discussion relevant.
John1397
Is there any way to take 12 volts dc from a car battery and have it go thru some components so that what comes out amounts to still 12 volts dc, but is limited to only 20 ma output?
John
I'm no expert by any means, but my first thought is to put a 20mA fuse in the circuit. I've never had a problem with that sort of thing, though; nothing that I've ever hooked up to my car (and there have been some seriously weird ones) ever drew more current than it needed. The fuse is more to prevent fire in the event of something overloading the capacity of the wires and/or solder junctions.
Sure. The simplest way is with a fuse, but of course the fuse is destroyed if the 20 mA is exceeded. There are many current limiting circuits, try a Google search on current limiting, or try this wiki site.
Maybe it goes without saying, but you do realize that if the load attempts to exceed the 20mA limit, the circuit will need to drop the voltage below 12V in order to limit the current.
Thanks, Phyzguy. I was out nuking my supper with the intention of editing and telling John to wait for an expert to give him better advice. I'm glad that you showed up before he plugged anything in.
There are many circuits for current limiters.
Have a look here for some of them:
https://www.google.com.au/search?q=...po6IB7rmgJgE&ved=0CAoQ_AUoAQ&biw=1024&bih=566
Here is one circuit that works
You have to calculate a value for the sense resistor that will make it drop 0.6 volts at the required current.
In this case, it will be about 30 ohms.
Using Ohm's Law,
Resistance = Voltage / current = 0.6 volts / 0.02 amps = 30 ohms.
But, as Physguy mentioned, you can't have it both ways. If you supply 12 volts to a 100 ohm resistive load, it will draw 120 mA.
Using Ohm's Law,
current = voltage / resistance
current =12 volts / 100 ohms = 0.12 amps = 120 mA
To make it draw only 20 mA you must reduce the voltage to 2 volts.
Using Ohm's Law,
current = 2 volts / 100 ohms = 0.02 amps = 20 mA
Ideally, what you need is a circuit that will give you a steady 12 volts out except if the load resistance is low enough that it will draw more than 20 mA. In this case, the output voltage must reduce enough that the load cannot draw more than 20 mA
Using Ohm's Law,
Using Ohm's Law,
Using Ohm's Law,
Looks like this would work would be nice if it came with resistor values diode type and transistor specifications as some of us folks are not that bright figuring this out ourselves.
The power ratings of components are also important in these power circuits.
What is it that you want 20 mA to go through?
That circuit will only give you about 10V output, though. You mentioned you still want 12V at the output, right? What are the specifications for the output? What tolerance can you tolerate in the output voltage.
If you want a true 12V at the output along with the 20mA current limiting, you will probably need to use a DC-DC converter, in a boost-buck or SEPIC topology. Also, 20mA is a pretty low current limit value -- what is the application?
From a 12 volt car battery you would have 300 amps all I want is 12 volts at 20 ma maximum the load will draw a maximum of 12 volts at 1 amp, but I do not want it drawing 1 amp only 20 ma and I do not care if voltage drops a lot this will not affect the circuit as the unit I am powering goes into shut down mode if the voltage drops below 11 volts, but still continues to work in sleep mode with only a small amount of voltage and amps.
Well, I suppose you could just put a 25 Ohm resistor in series wiith the feed to your device. That will drop 0.5V at 20mA, to give you 11.5V at 20mA for your device. If your device tries to draw more, that will drop the voltage below 11V and your device will go into low-current mode.
0.5V = 20mA * 25 Ohms
Will that do what you want?
Depends on what you connect? If you device wants to draw 20 mA, it will draw 20 mA. Just because the battery is capable of providing 300 amps, doesn't mean it will.
A little more information about your load would be helpful.
How close to 12 volts do you need voltage to be?
How close to 20 ma do you need the limit to be?
Your car battery is around 12-13 volts when parked and 14-15 while driving.
VK6 gave the basic approach in his post above - measure the current and control it with some active device. Often one sees a PNP transistor instead of NPN in his circuit; that allows lower voltage drop and is used in "Low Drop Out Voltage Regulators" - a search on that term will be instructive..
TI's LM2900 series is automotive LDO regulators with some nice features .
The electronics manufacturers learned about the need for these the hard way:
Reverse polarity protection: in case somebody hooks up the jumper cables backward it doesn't fry your regulator and its expensive load.
Overvoltage protection: When somebody leaves a battery terminal loose it will make intermittent connection. When the connection opens it's called a "load dump" and your alternator voltage spikes high before the car's voltage regulator can reduce excitation. That overvoltage wrecks non-automotive rated electronics in the car.
Temperature range to 125 degC. Under-hood is extreme environment, as is underdash near the heater .
Here's TI's LM2937 datasheet. It's available in 12 volt, or 10 volt if your load can work with that.
http://www.ti.com/lit/ds/symlink/lm2937.pdf
But it'll deliver around an amp into a short circuit until it gets hot and shuts itself down for thermal protection.
I often suggest an automotive regulator to hobbyists because of its accident-resisting features.
TI has a lot of new regulators since I last looked, so peruse their selection guides. "Zfoldback limiting" might be good for your application, sp read up on that.
If you need to get sophisticated with this project take a look at "High Side sensing"
http://www.maximintegrated.com/app-notes/index.mvp/id/746
http://www.analog.com/en/specialty-amplifiers/current-sense-amplifiers/adm4073/products/product.html
I envy you young fellows the sophisticated high-tech IC's you have available. But I am also aware there's so much of it as to be overwhelming.
Have fun, learn by doing.
old jim
  • · Replies 31 ·
