Limiting the torque and safety torque elements
12 replies · 2K views
Amaelle
Identify the elements of the safety clutches (look at the image)
safety clutches
Greetings
I need to identify the elements of the following safety cluches: we have three different clutches.
I lready identified most of them exept for number 14
Any help would be appreciated !
thank you!
1- output shaft
2-friction surface
3-preloaded spring
4-nut
5- input shaft
6- output shaft
7- input shaft
8-ogival seat
9-sphere
10-preloaded spring
11-nut
12-input shaft
13-output shaft
15-pin
is it a spline?
thank you!
1 seems not to be a shaft.
15 has a special characteristic.
Could 12 and 13 be either?
How are 5 and 7 transferring power to their mechanisms?
It should be the same for 14.
No spline seems to be represented.
thank you
5 is the input shaft
1 is the output shaft
on 1 there is a friction disk mounted (not repesented) so there is a friction between the friction disk and the friction surface
the friction surface is connected to the input shaft through a housing which transfer power.for the the middle picture
the input shaft 7 is connected to the preolad spring and the sphere. there is a friction between the sphere and an the ogival seat. the ogival seat is on the output shaft, so this is how the torque is transmitted.
Amaelle said:
thank you
No, no, before all that happens. :smile:
Why are splines needed?
  • Haha
I´m just guessing here,
maybe we need to connect the input shaft to another mechanisam and the spline gives a good way for it?
Perfect!
The part inmediately connected to the shaft needs to have a way to avoid rotating respect to the shaft.
Sometimes, both must keep a specific angular position respect to each other.
Again, we don’t have a spline here.
so no idea about this strange line?
Lnewqban said:
Perfect!
can this be a key slot?
thanks a million! was very rewarding discussing with you!
