Limiting the torque and safety torque elements
In summary, the safety cluches identify the elements of a power transmission system. The input shaft is connected to the preloaded spring and the sphere. The ogival seat is on the output shaft, so this is how the torque is transmitted. The key slot for the shaft, key itself, and key slot for the part onto which the torque is transferred via the key are all represented in the drawings.
Amaelle
310
54
Identify the elements of the safety clutches (look at the image)
safety clutches
Greetings
I need to identify the elements of the following safety cluches: we have three different clutches.
I lready identified most of them exept for number 14
Any help would be appreciated !
thank you!
1- output shaft
2-friction surface
3-preloaded spring
4-nut
5- input shaft
6- output shaft
7- input shaft
8-ogival seat
9-sphere
10-preloaded spring
11-nut
12-input shaft
13-output shaft
15-pin
is it a spline?
thank you!
1 seems not to be a shaft.
15 has a special characteristic.
Could 12 and 13 be either?
How are 5 and 7 transferring power to their mechanisms?
It should be the same for 14.
No spline seems to be represented.
thank you
5 is the input shaft
1 is the output shaft
on 1 there is a friction disk mounted (not repesented) so there is a friction between the friction disk and the friction surface
the friction surface is connected to the input shaft through a housing which transfer power.for the the middle picture
the input shaft 7 is connected to the preolad spring and the sphere. there is a friction between the sphere and an the ogival seat. the ogival seat is on the output shaft, so this is how the torque is transmitted.
Amaelle said:
thank you
No, no, before all that happens. :smile:
Why are splines needed?
  • Haha
Likes Amaelle
I´m just guessing here,
maybe we need to connect the input shaft to another mechanisam and the spline gives a good way for it?
Likes Lnewqban
Perfect!
The part inmediately connected to the shaft needs to have a way to avoid rotating respect to the shaft.
Sometimes, both must keep a specific angular position respect to each other.
Again, we don’t have a spline here.
Likes Amaelle
so no idea about this strange line?
Lnewqban said:
Perfect!
can this be a key slot?
Likes Lnewqban
thanks a million! was very rewarding discussing with you!
Likes Lnewqban
Likewise, Amaelle. :smile:
Likes Amaelle
Likes Amaelle
Related to Limiting the torque and safety torque elements
1. What is the purpose of limiting the torque in a machine?
The purpose of limiting the torque in a machine is to prevent excessive force or power from being applied, which can lead to damage or failure of the machine. This ensures the safety of the machine and its operators.
2. How is torque limited in a machine?
Torque can be limited in a machine through various methods such as using a torque limiter, a torque sensor, or a torque control system. These elements can be designed to either automatically cut off power when a certain torque limit is reached or provide a warning signal to the operator.
3. What are some common safety torque elements used in machines?
Some common safety torque elements used in machines include torque limiters, overload clutches, shear pins, and torque sensors. These elements are designed to limit or control the amount of torque applied to the machine, ensuring its safe operation.
4. How does limiting the torque affect the performance of a machine?
Limiting the torque can affect the performance of a machine by reducing its maximum power output. However, this trade-off is necessary to ensure the safety and longevity of the machine. Properly limiting the torque can also improve the precision and accuracy of the machine's operation.
5. Why is it important to have safety torque elements in machines?
Having safety torque elements in machines is crucial for the safety of both the machine and its operators. These elements prevent the machine from being damaged or causing harm due to excessive force or torque. They also help to maintain the efficiency and reliability of the machine over time.
  • Mechanical Engineering
  • Nuclear Engineering
  • STEM Educators and Teaching
  • MATLAB, Maple, Mathematica, LaTeX
