Limits, L'Hospital's Rule & Trigonometry
The discussion revolves around finding the limit of a trigonometric expression as x approaches pi/2 from the right, specifically using L'Hospital's Rule and considering alternative methods. The problem involves understanding the behavior of sine and cosine functions near this limit point.
  • Participants explore the application of L'Hospital's Rule to the limit, questioning the behavior of the functions involved as x approaches pi/2. There is discussion about the signs of sine and cosine near this limit and how they affect the outcome.
Participants are actively engaging with the problem, offering insights and clarifications about the limit's behavior. Some have provided reasoning regarding the signs of the functions involved, while others express confusion about the implications of these signs on the limit's value. There is no explicit consensus, but several productive lines of reasoning have emerged.
The original limit is noted to have the indeterminate form 0/0, which justifies the use of L'Hospital's Rule. Participants are also discussing the implications of approaching the limit from the right side and the behavior of the cosine function in that region.
CougarXLS
SOLVED, thanks to Dick and viciousp!
The question asks: Find the limit. Use L'Hospital's Rule where appropriate. If there is a more elementary method, consider using it. If L'Hospital's Rule doesn't apply, explain why.
Limit as x approaches pi/2 from the right (+) of given equation:
lim [x -> (pi/2)+] of [(cos x) / (1 - sin x)]
Possibly trig identity: tan x = sin x / cos x
L'Hosptial's Rule: lim(x->a) of f(x)/g(x) = lim(x->a) of fprime(x) / gprime(x)
= lim [x -> (pi/2)+] of [(-sin x) / (-cos x)] ---> using L'Hosptial's Rule
= lim [x -> (pi/2)+] of [(tan x)] ---> using trig identity tan x = sin x / cos x
--> tan (pi/2) is undefined. Therefore my solution would be infinity.
I don't understand how the answer is negative infinity. LOL, my answer disagreeing with the book again... lol... I know it's probably me.
Could someone please explain to me how it's negative infinity and not infinity?
Think about it. If x is a little bigger than pi/2 then -sin(x) is approximately -1, and cos(x) is a small negative number, so -cos(x) is a small positive number. -1/(small positive) -> -infinity. Seeing the tan(x) is undefined tells you it's one of the infinities, but doesn't tell you which.
But it's not -sin x... the negatives canceled out...
lim [x->pi/2]+ of -sinx / -cosx leaves a positive (the -1 cancels out)
I don't understand. Even if (pi/2) is slightly bigger (as approaching from right), then sin x still goes to 1, not -1.
I don't mean to be difficult; I wish to understand.
Thanks.
You are just moving the -1 around. Ok, sin(x) goes to 1. cos(x) is a small negative. 1/(small negative) -> -infinity.
Forgive me, but if the negatives canceled out, how do I know to 'move the -1' around?
I realize that tan x is undefined and that it tells you it's one of the infinities, but doesn't tell you which... from that I concluded that because the -1 canceled out, the resulting limit would be positive.
Wow, I am confused... :)
Limit x->pi/2+ of tan(x) is -infinity. Because sin(x)->1 (as you said) and cos(x) is a small negative number. Just because cos(x) doesn't have a '-' in front of it doesn't mean it can't be negative. Look at a graph of cos(x).
Okay, what you say makes sense, but how do I know which it is?
When I look at the graph of f(x)=cos x, I can understand how it can yield a negative value. What I don't understand is how, from the equation I am finding the limit of, how can I determine that a -1 is still hanging around?
Is there some trig trick/identity/rule I am missing?
cos(pi/2)=0
between 0 and pi/2 cos is positive
between pi/2 and pi cos is negative
cos(pi)=-1
Since we are coming from the right the value of cosine is always negative but increasing (getting closer to zero)
The original limit has the form 0/0. That means you can apply l'Hopital to the limit. You got tan(x). The limit of tan(x) as x->pi/2+ is minus infinity. l'Hopital's rule then tells you that is also the value of the original limit.
Yes, I am with you so far.
In typing this response, I seem to have neglected the observation that I am taking the limit from the right and that All Students Take Calculus... aka tan (pi/2 + 0.01) < 0 (where 0.01 is some very small positive number)! Which of course is negative.
Sometimes I think I am in over my head. lol
Lol, that's the one part of this section I understand.
Thanks Dick and viciousp (for reminding me of C.A.S.T., it was your post that jogged that old omen). I get it know.
What can I say... lol, it's been four years out of high school and into first year university.
Thanks for your help!
I'm sure I'll be back ;) If not for calculus (which I seem to be understanding most of the concepts), then for trigonometry (for some reason, it just doesn't sit well in my brain). LOL
Thanks all.
  • · Replies 23 ·
  • · Replies 20 ·
