[LinAlg] Describe Ker(T) using set notation for T:P^1 -> R
The problem involves describing the kernel of a linear transformation \( T: \mathbb{P}^1 \rightarrow \mathbb{R} \) defined by \( T(p(x)) = \int_0^1 p(x)~dx \) using set notation. The context is within linear algebra, specifically focusing on the properties of transformations and their kernels.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the definition of the kernel and attempt to express it in set notation. There are considerations about the integration process and the conditions under which \( T(p(x)) = 0 \). Some participants also question the notation used for the kernel, discussing the differences between \( \text{Ker}(T) \) and \( Ker(T) \).
The discussion includes multiple attempts to articulate the kernel in set notation, with some participants affirming the correctness of the expressions provided. There is an ongoing dialogue about the appropriate notation for the kernel, indicating a productive exploration of formatting conventions in LaTeX.
Participants note the potential for confusion regarding the notation for the kernel and the implications of using different styles. There is also mention of the challenges posed by LaTeX formatting in the context of the forum.
bornofflame
2. Let ##T: \mathbb{P}^1 \rightarrow \mathbb{R} \text{ be given by } T(p(x)) = \int_0^1 p(x)~dx## Describe ##Ker(T)## using set notation.
##p(x) \in \mathbb{P}^1~|~ p(x) = a_0 + a_1x##
##T: \mathbb{P}^1 \rightarrow \mathbb{R}## is a mapping/transformation from ##\mathbb{P}^1 \text{ to } \mathbb{R}##.
For ##p(x)## in ##\mathbb{P}^1 \rm , T(p(x))## is the image of ##p(x)## under the action of T. For each p(x) in ##\mathbb{P}^1 \rm , \int_0^1 p(x)~dx## is computed as ##T(p(x)) = Ax = \int_0^1 p(x)~dx = 0##
For p(x) to be mapped to the null space then T(p(x)) must be 0 which means that ##\int_0^1 p(x)~dx=0## which is really ##\int_0^1 a_0 + a_1x~dx = 0##.
Then by integrating we get ##a_0x + \frac 1 2 a_1 x^2 ~|_0^1##.
##a_0 + \frac 1 2 a_1 = 0##
##a_0 = -\frac 1 2 a_1##
Then
##Ker T = \{p(x) = a_0 + a_1x ~|~ a_0 = -\frac 1 2 a_1\}##
Then
That's correct.
Then
By ##Ker(T)##, do you really mean ##\text{Ker} (T)##? They look very different! You get the second one by typing "\text{Ker}" instead of "Ker", as required by LaTeX when used properly.
Anyway, you could write ##\text{Ker}(T)## as
$$\bigcup_{a \in \mathbf{R}} \{ p \in \mathbf{P}^1 | p(x) = a - 2ax \}$$
Now, now, it's pretty clear what he meant. IMO, this is really nit-picking.
fresh_42 said:
That's correct.
Great! Thanks! I wasn't quite sure about it. It seemed really simple but really complex at the same time.
Is there a standard style for Ker? ##Ker(T)## is how it's been presented to me.
I regard is as a contribution to his education. Maybe he did not know about that before, but now he probably does. Certainly it has done him no harm!
Probably mistakenly; LaTeX manuals are pretty explicit about such matters, but sometimes people who write notes and lectures may be c
In the AMSMath package there is a command "\ker" that typesets it in the "approved" way, but I don't think the version of LaTeX available in this forum has it. I think the AMSMath version gives ##\text{ker} (T)## instead of ##\text{Ker} (T)##.
Alright. I'll try to keep that in mind then.
There are standard functions like \lim, \sin, \log which result in ##\lim, \sin, \log## instead of ##lim, sin, log## which I've written without backslash. However, there are many such conventions which don't have a backslash version. Not sure, whether the kernel is among them. Let's test it:
\ker ##\longrightarrow \ker##
\Ker ##\longrightarrow \Ker##
\im ##\longrightarrow \im##
In case of doubt, i.e. if you don't want to try or look it up, there is a version which always works:
\operatorname{works} results in ##\operatorname{works}## instead of simply ##works##.
I wouldn't go so far as to say they look "very different."
What @bornofflame wrote was clear and unambiguous LaTeX, quite an accomplishment for a fairly new member here. A critque on such a nit as ##Ker(T)## versus ##\text{Ker}(T)## (the latter of which requires twice the typing for a very marginal difference) could at least been more diplomatically presented, in my view. By writing "do you really mean ..." there's the suggestion that the one form is incorrect and the other is correct.
For what its worth, I can assure you that others have learned some ideas / techniques from Ray's past formatting pointers. Putting the leading slash in front for things like cosine ##cos(x) \to \cos(x)## is the low hanging fruit.
For non-qualifying ones like ##\text{Ker}(T)## what I've started doing is just writing it as ##Ker(T)## and then at the very end, if I remember,
do a find and replace "Ker(" with "\text{Ker}("
in my editor -- Jupyter notebooks in this case
It really is twice as much work if you do it on your own each each time you type in the term Ker, but almost no more work if you do the find and replace at the very end before submitting your post.
I agree with @Mark44. The OP used the kernel twice and both cases could easily be recognized as such. We could as well debate whether the kernel could be denoted with a capital K or not, or if an image should be abbreviated by ##\operatorname{im}## or ##\operatorname{img}##, or whether ##21\,°C## room temperature is better than ##20.5°\,C##.
Edit: Good tip with the replacement, but inconvenient if a) my browser doesn't support it and I don't use an extra editor to write here, or b) there are various locations with different operators. E.g. I regular have ##\operatorname{ad}##, ##\operatorname{Ad}##, ##\operatorname{GL}(V)##, ##\operatorname{ker}##, ##\operatorname{rk}##, etc. Ooops, sorry, I am guilty! I write ##GL(V)## and not ##\operatorname{GL}(V)##. Mea culpa.
I believe you can copy paste your writeup into a regular text editor like Word and do a find and replace all from there. I think any decent one can do that, though the one I use in Ubuntu messes up spacing for some reason?
I don't have any great ideas when there are multiple problem ones -- though a simple python script that runs a through a list of the ones commonly used that aren't "backslashable" comes to mind. If I get around to making such a script maybe I'll share it in the "MATLAB, Maple, Mathematica, LaTeX, Etc" folder...
Sure, but a change of platforms isn't very convenient.
I installed a little tool which allows me to define my own shortcuts. E.g. ##\operatorname{Ker}## is on my keyboard: Ctrl+o , arrow left, Ker, arrow right. The arrows are, because I encoded \operatorname{} with brackets, because the arrows are much faster to type than the brackets. It's enormously helpful, e.g. for expressions like \left. \dfrac{d}{d}\right|_{}
  • · Replies 24 ·
