Line integral of a vector field over a square curve
The discussion focuses on evaluating the line integral of the vector field \(\vec{v} = (y, 0, 0)\) over a square curve in the xy-plane using both direct integration and Stokes' theorem. Participants express confusion about the integration limits and the role of \(\vec{r}\) in the calculations. Direct integration involves breaking the square into four segments, leading to an integral that ultimately evaluates to \(a^2/2\) for each side. For Stokes' theorem, the discussion concludes that the integral relates to the curl of \(\vec{v}\) multiplied by the area of the square, which is \(a^2\), though the sign remains a point of clarification. Overall, both methods yield consistent results when properly applied.
marineric
Please evaluate the line integral \oint dr\cdot\vec{v}, where \vec{v} = (y, 0, 0) along the curve C that is a square in the xy-plane of side length a center at \vec{r} = 0
a) by direct integration
b) by Stokes' theorem
Stokes' theorem: \oint V \cdot dr = ∫∫ (∇ x V)\cdotn d\sigma
I know I have to split up the sides of the square. I get confused when \vec{r} is involved. I know the limits are at a/2.. not sure where to go after that.
For the direct integration, just write it out. What is d\vec{r} \cdot \vec{v}? Since you're integrating over a square, you can just write the integral as a sum of four one-dimensional integrals wrt. x and y.
Ok well I'll try the top line of the square and you can tell me what I'm doing wrong.
From left to right:
\oint d\vec{r}\cdot\vec{v} from -a/2 to a/2
\vec{v} = (y,0,0)
\vec{r} = (x, a/2, 0)
d\vec{r} = (1, 0, 0)
d\vec{r}\cdot\vec{v} = y
but aren't the y limits a/2 to a/2, making the integral zero?
wait hold on \vec{r} = (d\vec{x}, 0, 0) ??
then it would be the integral from -a/2 to a/2 of y*dx where y = a/2?
but that's (a/2*x) from -a/2 to a/2 ... which equals zero?
Are you sure it equals zero? :)
oh, right, minus sign.. so it equals a^2/2 for the top line, and i just do it similarly for all the other sides? do i have to do it in the same order (clockwise)?
You got it
for the stokes' theorem part, would it just be the ∇\times\vec{v} times the area of the square, which is a^2?
Yep, although it's not immediately clear what's the correct sign.
