Line integral over a vector field
In summary: Vector field, F = < −y, x − 1 > = -y i + (x-1) j F(r(t)) = (-sin(t))i + (cos(t)-1)jr(t) = cos(t)i+sin(t)jr'(t) = -sin(t)i+cos(t)jF(r(t))⋅r'(t)=sin2(t)+cos2(t)-1Now I need to evaluate that between the regions 0≤t≤πI just wanted to check if I've set this up correctly. The arc from point
says
594
Evaluate ∫C < −y, x − 1 > dr where C is the closed piecewise continuous curve formed by the line segment joining the point A(− √ 2, √ 2) to the point B( √ 2, − √ 2) followed by the arch of the circle of radius 2, centered at the origin, from B to A.
2. The attempt at a solution
F
r
r
F
I just wanted to check if I've set this up correctly. The arc from point B to A is = 180°= π, so that's why I've defined the region of t as going from 0≤t≤π.
F
r
r
F
Your parameterization is not a circle of radius ##2##. And your ##t## range is incorrect. It needs to start at the right place when ##t=0##.
Oh, I forgot the radius = 2. I think (below) is better!
r(t) = 2cos(t)i+2sin(t)j
r'(t) = -2sin(t)i+2cos(t)j
As for the range.
( √ 2, − √ 2)≤t≤(− √ 2, √ 2)
This is the same as the range 0≤t≤π.
r
As for the range.
No it isn't. ##\vec r(0) =\langle 2,0\rangle##.
The same radial distance*
edit: not sure if you were correcting my last statement or my r(t)?
7π/4≤t≤3π/4
says said:
As for the range.
This makes no sense. t is a real number that you're comparing to two points. In addition there is no ordering principle for points, so you can't say ( √ 2, − √ 2) ≤ (− √ 2, √ 2)
7π/4≤t≤3π/4
This is saying, among other things, that 7π/4 ≤ 3π/4, which is clearly not true.
Ok. I see what you mean. I'm not sure where to go from here though with defining the range...
Your original post did not tell you which arch to take getting back from B to A. You have to decide that first and make sure your parameterization goes in the correct direction, either clockwise or counterclockwise. Then you need to think about what geometric angle ##t## represents in your parameterization. Make sure it starts at B and traverses the arch to A in the direction you want.
I'm having trouble understanding what you mean, sorry. I'm assuming we are calculating the integral from B to A, so it's counterclockwise. It start at an angle of 315 degrees, and finishes at an angle of 135 degrees, a difference of 180 degrees.
I understood the question to mean that we have a vector field, < −y, x − 1 >, and a path from point B to point A, which followed the arc of a circle that was centred at the origin and had a radius 2. i.e. I pictured it as a particle moving in a semi-circle from point B to point A. The particle's path is determined by the field vector, F, and it's own movement, r(t). (Sorry if I don't sound to mathematically rigorous here, I'm still trying to get the intuition of line integrals over vector fields.)
While there is nothing wrong with assuming it is counterclockwise, your original problem doesn't say that. It's OK with me to assume that, but understand that you could just as well go clockwise on the circle from B to A, and the answers are probably different. The direction should have been stated in the problem, or maybe you just left it out. Now, assuming you want to go counterclockwise and start at 315 degrees, you won't end at 135 degrees. Counterclockwise motion adds to the angle.
Yes. You just didn't specify which semi-circle. See above.
The particles path is determined by ##\vec r(t)##, not by the field vector ##\vec F##. The vector field affects how much work is done in the process.
Ok, I'm trying to understand that comment a bit more with a much simpler example. I jump from point B to point A. I only got to point A because I put in positive work, while the vector field (gravity) did negative work, which made me land at point A. The amount of work I did in getting from B to A is equal to the ∫F(r(t))⋅r'(t).
But back to the question:
If I start at 315 degrees, i.e. 315 degrees = 0, and I end at 135 degrees, that would mean I start at 0 degrees and end at 180 degrees. So 0≤t≤180 or 0≤t≤π. I calculated the integral with this range and got -π as a result.
That integral calculates the work done by the vector field.
##315\ne 0##. And it doesn't agree with ##t=0## either. See below
You need to show your work. Are you still using ##\vec r(t) = 2\cos t i + 2\sin(t) j##? If so, I have pointed out to you before that when ##t=0## it gives (2,0). And at ##t=\pi## it gives ##(-2,0)##. That does not describe the correct semicircle.
1. What is a line integral over a vector field?
A line integral over a vector field is a mathematical concept that calculates the sum of the values of a vector field along a given curve. It is used to determine the work done by a force along a specific path.
2. How do you calculate a line integral over a vector field?
To calculate a line integral over a vector field, you first need to parameterize the given curve and then integrate the dot product of the vector field and the tangent vector of the curve with respect to the parameter. This can be done using the fundamental theorem of line integrals or by using the line integral formula.
3. What is the significance of line integrals over vector fields in physics?
In physics, line integrals over vector fields are used to calculate the work done by a force along a specific path. They are also used to calculate other physical quantities such as electric field, magnetic field, and fluid flow.
4. What are some real-world applications of line integrals over vector fields?
Line integrals over vector fields have various applications in engineering, physics, and mathematics. Some examples include calculating the work done by a force on an object, determining the circulation of a fluid, and computing the flux of a vector field through a surface.
5. How does the orientation of the curve affect the value of a line integral over a vector field?
The orientation of the curve does not affect the value of a line integral over a vector field as long as the start and end points of the curve remain the same. However, if the direction of the curve is reversed, the sign of the line integral will also be reversed.
