Linear acceleration to angular acceleration
The discussion focuses on calculating angular acceleration from linear acceleration, specifically using a linear acceleration of 70 G's and a cylinder radius of 0.203 m. The initial calculation provided results in an angular acceleration of 5305 rad/s², but participants question the relevance of the cylinder's rotation and the unit conversions involved. Clarifications are made regarding the relationship between linear and angular quantities, emphasizing that radians are dimensionless and can be omitted in certain calculations. The consensus is that while the formula α = a/r is correct, understanding the units and their cancellations is crucial for accurate calculations. Overall, the conversation highlights the importance of unit consistency in physics equations.
pines344
I am working on a project where i need to determine the angular acceleration from known linear acceleration. I have given it a try please let me know if its the correct approach.
Linear acceleration = 70 G's (70x9.8 mts/sec2)
Radius of cylinder = 0.203 mts
Rotation of cylinder along center = \pi/2
Angular acceleration = (70*9.8) (mts/sec2)/(0.203 mts) *(\pi/2)
= 5305 rad/sec2
Please confirm if my calculation is correct.
hi pines344! :smile:
(have a pi: π and always abbreviate "metres" and "seconds" simply as "m" and "s" :wink:)
i don't understand what "Rotation of cylinder along center" has to do with it :confused:
what exactly is the original question?
usually, you convert simply by dividing by the radius …
arc-distance = radius x angle (s = rθ))
speed = radius x angular speed (v = rω)
acceleration = radius x angular acceleration (a = rα))​
if linear acceleration = radius x angular acceleration (a = rα)
How would the units work out here:
Linear acceleration = m/s2
radius = m
angular acceleration = rad/s2.
based on above formula
m/s2 = m x rad/s2. They do not balance which is something that is is confusing to me. Please explain how it works out.
Radians are dimensionless.
pines344 said:
based on above formula ... m/s2 = m x rad/s2. They do not balance.
The unit radian can be dropped in mathematical expressions where there is conversion into linear motion. So m x rad/s2 is the same as m/s2 if the surface speed is consider as a linear speed instead of an angular speed.
Is it the same if i am calculating the angular acceleration(\alpha) from linear acceleration (a)
\alpha = a/r
rad/s2 = (m/s2)/m, where m and m cancel and only 1/s2 is left where does rad come into picture?
Although a radian is a unit of angular displacement, it's not the same type of unit as a second, meter, or kilogram. An angular displacement times the radius of a rotating object corresponds to a distance, but the units will be the units of the radius, such as meters or feet, and the term radians would be dropped from the product when describing the distance.
For example, the distance of the path of a point on the circumference of a circle with a radius of 2 meters rotated by 3 radians would equal 6 meters (note the unit radians is dropped from the product).
The same principle applies to angular velocity or angular acceleration. Once multiplied by the radius to get the equivalent surface velocity or acceleration, the unit radian is dropped from the product.
  • · Replies 20 ·
  • · Replies 30 ·
  • · Replies 22 ·
