Linear Algebra: Characterizations of invertible matrices
The discussion revolves around the properties of a linear transformation T that maps Rn onto Rn, specifically focusing on the existence and characteristics of its inverse T-1. Participants are exploring the implications of T being invertible and the conditions under which T-1 also maps Rn onto Rn and is one-to-one.
  • The original poster attempts to connect the invertibility of the transformation T to the properties of the associated matrix A, referencing the Invertible Matrix Theorem and Theorem 9. They question whether their reasoning is sufficient to prove the existence of T-1 and its properties.
  • Some participants express uncertainty about specific theorems and their implications, seeking clarification on the definitions and relationships involved.
  • Others suggest examining the implications of T being onto and how that relates to the mapping properties of T-1.
The discussion is active, with participants providing insights into the proof structure and questioning the assumptions made. There is an ongoing exploration of how to demonstrate that T-1 exists and its mapping properties, with no explicit consensus reached yet.
Participants are navigating through theorems and definitions that may not be universally known among them, indicating a potential gap in shared knowledge regarding the relevant mathematical concepts.
freeski
Let T be a linear transformation that maps Rn onto Rn.
Show that T-1 exists and maps Rn onto Rn.
Is T-1 also one to one?
I am not quite sure where to start. To prove that T is invertible I need to show that A is an invertible matrix. To show that A is an invertible matrix I can use The Invertible Matrix Theorem part i. "The linear transformation x → Ax maps Rn onto Rn
This theorem also says that if part i. is true then A is an invertible matrix.
Then, by theorem 9, T is invertible because A is invertible.
Is that enough to prove that T-1 exists? How do I show that it maps Rn onto Rn? Is it also 1-1?
I don't know that theorem 9 and part i. are! I'm not taking your class with you.
Theorem 9
Let T: R^n → R^n be a linear transformation and let A be the standard matrix for T. Then T is invertible if and only if A is an invertible matrix. In that case, the linear transformation S given by S(x) = A^-1 x is the unique function satisfying
(1) S(T(x)) = x for all x in R^n
(2) T(S(x)) = x for all x in R^n
part i. is from the Invertible Matrix Theorem
Let A be a square nxn matrix. Then the following statements are logically equivalent:
a. A is an invertible matrix
b. A is row equivalent to the nxn identity matrix
c. A has n pivot positions
d. The equation Ax = 0 has only the trivial solution
e. The columns of A form a linearly independent set
f. The linear transformation x→ Ax is one-to-one
g. The equation Ax= b has at least one solution for each b in R^n
h. The columns of A span R^n
i. The linear transformation x → Ax maps R^n onto R^n
j. There is an nxn matrix C such that CA = I
k. There is an nxn matrix D such that DA = I
l. A^T is an invertible matrix.
Okay, from what I understand of your proof, you are using part (i) to conclude that the matrix associated with T is invertible.
You are then using "Theorem 9" to conclude that because the matrix associated with T is invertible, T itself must be. So far, we have that T is invertible so that T-1 exists.
To show that it maps Rn onto Rn, note that because T is onto, given an arbitrary v1 in Rn, one can find v2 in Rn so that T(v1) = v2. Apply the inverse to both sides of this equation and see what you get. Note that v1 was arbitrary.
To show that it's 1-1, suppose that we have v1, v2 with T-1(v1) = T-1(v2). Again, just operate on both sides of the equation with T.
