Linear Algebra- Dependent or independent
The discussion revolves around determining whether the set {v1-v2, v2-v3, v3-v1} is linearly dependent or independent, given that v1, v2, and v3 are linearly independent vectors. The initial analysis concluded that since c1, c2, and c3 must all equal zero, the new set is independent. However, it was clarified that finding c1 = c2 = c3 does not necessarily imply they are all zero, as the relationship between the new vectors does not directly correlate with the independence of the original vectors. The key takeaway is that linear independence of the original vectors does not guarantee the same for the derived set, which is actually linearly dependent. Understanding this distinction is crucial for mastering concepts in linear algebra.
MozAngeles
Let(v1, v2, v3) be three linearly independent vectors in a vector space V. Is the set {v1-v2, v2-v3, v3-v1} linearly dependent or independent?
Linearly independent is when c1v1+c2v2+...+ckvk=0
and c1=c2=...ck=0
c1(v1-v2)+ c2(v2-v3)+ c3(v3-v1)=0
c1-c3=0
-c1+c2=0
-c2+c3=0
therefore c1=c2=c3 and since c1, c2 and c3 are zero because for the first set of independent vectors I got c1v1+c2v2+c3v3=0 all c1=c2=c3=0,
which means this is the case for the second set and it must be linearly independent.
This is what i got but my answer key says the second set is linearly dependent. I'm having trouble seeing why.
Thanks for any help
and c1=c2=...ck=0
c1-c3=0
-c1+c2=0
-c2+c3=0
Thanks for any help
Can you explain in detail how you concluded from c1=c2=c3 that c1, c2 and c3 are zero?
from my set of equations i concluded that c1=c2=c3. So then I had made the assumption that c1=c2=c3 was zero because from the given set v1, v2, v3 being linearly indepedent, which would mean that c1v1+c2v2+c3v3=0 must have c1=c2=c3 from the definition of linear dependence. I assumed they were the same constants, is this wrong to assume?
##v_1,v_2,v_3## being linearly independent means that if ##d_1v_1+d_2v_2+d_3v_3=0##, then ##d_1=0,d_2=0,d_3=0##.
There is no reason whatsoever to assume that the numbers ##c_1,c_2,c_3## that you chose for the set {##v_1-v_2, v_2-v_3, v_3-v_1##} must also work for ##v_1,v_2,v_3##.
but even still for my set of {v1-v2,v2-v1...} the c1=c2=c3 are all equall and I had set my equations to equal zero, then the only way this will be true is if they all equal zero, right?
Why? All you found is that ##c_1=c_2=c_3##.
That seems sufficient to have ##c_1(v_1-v_2)+c_2(v_2-v_3)+c_3(v_3-v_1)=0##.
Ok, I'm seeing it clearer now. Thank you
I would add that because the vectors are linearly independent, there can be no other solutions for the constants ##d_1, d_2,## and ##d_3##.
If the three vectors were linearly dependent, the equation ##d_1v_1+d_2v_2+d_3v_3=0## would have an infinite number of solutions for the constants, including ##d_1=0,d_2=0,d_3=0##. This is a fine point that often eludes new students of linear algebra.
Likes MozAngeles
