Linear Algebra: Linear dependence of vectors?
The discussion centers on determining the conditions under which the vector v_3 = (2, -9, h) is in the span of the vectors v_1 = (1, -5, -3) and v_2 = (-2, 10, 6), and when the set {v_1, v_2, v_3} is linearly dependent. It is established that v_3 cannot be expressed as a linear combination of v_1 and v_2 for any value of h, indicating that {v_1, v_2, v_3} is linearly independent. The span of v_1 and v_2 is a line in R3, not a plane, due to their linear dependence (v_2 = -2v_1).
  • Understanding of vector spaces and spans in linear algebra
  • Knowledge of linear combinations and linear dependence
  • Familiarity with R3 coordinate systems
  • Basic proficiency in solving linear equations
  • Study the concept of linear combinations in vector spaces
  • Learn about the criteria for linear dependence and independence of vectors
  • Explore the geometric interpretation of spans in R3
  • Investigate the implications of dimension in vector spaces
Students and educators in linear algebra, mathematicians analyzing vector relationships, and anyone seeking to deepen their understanding of vector spaces and linear dependence.
SticksandStones
Given:
v_1 = \left(\begin{array}{cc}1\\-5\\-3\end{array}\right)<br /> <br /> v_2 = \left(\begin{array}{cc}-2\\10\\6\end{array}\right)<br /> <br /> v_3 = \left(\begin{array}{cc}2\\-9\\h\end{array}\right)<br /> <br />
For what value of h is v_3 in Span{v_1, v_2} and for what value of h is {v_1,v_2,v_3} linearly dependent?
If my understanding is correct, a vector is in a span of another set of vectors if all vectors are in the same plane? If so then my guess is h would have to be a multiple of -3.
The linear dependence part of the question is getting me though. I was under the impression that all three vectors would have to be multiples of each other for it to be linearly dependent?
For the first question.
How can you express the vector space V=Span\{u_1,u_2\}?
A plane?
Yes, and the equation that desribes that plane, is which?
SticksandStones said:
Given:
You understanding is not quite correct. A vector is in a span of another set of vectors if it can be written as a linear combination of the vectors in the set. The span of the set of vectors is a plane only if there are exactly two independent vectors in the set. That is not true in this problem!
Are these really the problem you were given? Have you copied the vectors correctly? Notice that -2v1= v2. The span of these two vectors has dimension 1, not 2. v3 will be in their span only if it also is a multiple of either v1 or v2. The first component of v3, 2, is 2 times the first component of v1 (and -1 times the first component of v2) but the second component of v3 is -9 which is not 2 times the second component of v1 (and not -1 times the second component of v2).
v3 while not be in the span of v1 and v2 for any value of h.
(If the second component of v3 were -10, then v3 would be in the span of v1 and v2 for h= -6.)
Ahhh, Ok. That makes a lot more sense.
Yes, these really are the vectors.
Just because making assumptions has burned me in the past, you mean the span is a line, correct?
After going back and re-reading the chapter this is what I thought. Thanks for confirming it though.
Since v3 isn't a linear combination of v1 and v2, this means that the set of {v1, v2, v3} has to be linearly independent, right?
Yes, the linear span of v1 and v2 is a line in R3.
What does it mean for the set to be linearly independent? If it is linearly independent, you should not be able to represent any vector as a linear combination of the other 2. But haven't you just shown (or Halls did) that v1 and v2 are multiples of each other?
