Linear Algebra linear independence
To prove that the vectors u + v, u - v, and u - 2v + w are linearly independent, it is essential to show that the equation c1(u + v) + c2(u - v) + c3(u - 2v + w) = 0 has only the trivial solution where all constants c1, c2, and c3 equal zero. This can be established by leveraging the linear independence of the original vectors u, v, and w. The discussion emphasizes that the same principles apply to whole vectors as they do to their coordinates, negating any confusion about the distinction between the two. Additionally, participants suggest consulting textbooks for a deeper understanding of linear independence and dependence concepts. The thread concludes by reinforcing the importance of foundational definitions in vector spaces.
Fanta
If u,v andw are three linearly independent vectors of some vectorial space V, show that u + v , u-v and u -2v + w are also linearly independent.
Okay, first of all, i know that:
\lambda_{1} \times u + \lambda_{2} \times v + \lambda_{3} \times w = (0,0,0)
admits only the solution that all lambdas = 0, but how can I proove that they are linearly independent, knowing so little?
I'd say to set it up in matrix form and check to see if the determinant is non-zero or row-reduce and if there is no row of all zeros at the end, it's linearly independent.
Edit: If matrices aren't allowed, show that for a system with constants multiplied by your u, v and w coefficients, each constant must be zero.
e.g.
Solve
1*a+1*b=0
1*a-1*b=0
1*a-2*b+c=0
Show that the equation c1(u + v) + c2(u - v) + c3(u - 2v + w) = 0 has only a single solution for the constants ci, using the fact that u, v, and w are linearly independent.
that's the process you would normally use when dealing with coordinatse.
But since we are dealing with whole vectors (instead of each vector's coordinates), would that really work?
For example, if I wanted to proove that vectors a b and c were linear independent:
Given a = (1,0,0), b = (0,1,0) and c = (0,0,1), we'd just do that same process, dealing with coordinates (c1(1,0,0) + c2(0,1,0)... = (0, 0, 0)
The confusion rises because we are multiplying constants with vectors, not coordinates.
This definition applies whether you know the coordinates or not.
Again, you are making a false distinction. Try what I suggested.
didn't know it applied to vectors too. Thanks.
Is there anywhere i can read on about that to get a better feel for the theory behind it?
And could I use the same principle to prove linear dependece on a problem, again with three vectors (u, v and w), but not necessairly linear independent, such that : w = 2u + v
Presumably you have a textbook. Look up the definitions of linear independence and linear dependence.
