Linear Algebra - Orthogonal Vectors
The discussion revolves around finding a nonzero vector that is orthogonal to three given vectors in a three-dimensional space. The vectors in question are v1=(1, -1, 2), v2=(2, 1, 3), and v3=(1, -4, 3). Participants explore the concept of orthogonality and the methods to determine such a vector.
  • Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss using the dot product to establish orthogonality and suggest setting up equations based on the dot products of an unknown vector with the given vectors. There are mentions of solving systems of equations and using row reduction or cross products to find solutions.
Some participants have offered guidance on how to approach the problem, including setting equations based on the dot products and discussing the implications of linear dependence among the vectors. There is an ongoing exploration of methods to find a nonzero solution, with some expressing confusion about the uniqueness of such a solution.
There is a recognition that the three vectors may not be linearly independent, which raises questions about the existence of a nonzero vector orthogonal to all three. Participants are navigating the implications of this potential dependence in their reasoning.
verd
I'm a bit confused, conceptually. This is the problem
Let v1=( 1, -1, 2) v2=( 2, 1, 3) v3=( 1, -4, 3)
Find a nonzero vector u that is orthogonal to all three vectors v1, v2, and v3. I know how to find the projection matrix, P, which I can solve with v1, v2, and v3.
The equation for that is simply p=A(AT A)^-1AT
(Where AT is A transposed)However, I'm not sure exactly what P is... I know it's the projection matrix, but if I solved this, would this give me a matrix that is orthogonal to A? (Assuming A is spanned by v1, v2, and v3). If so, would I just be able to take one of the column vectors from this matrix and assume that it is orthogonal to v1 v2 and v3??
If I'm going in the wrong direction, can someone tell me how to find a vector that is orthogonal to A?Thanks!
Two ways. Write the equations a.v1=0, a.v2=0 and a.v3=0 with 'a' unknown and solve the system for the components of a. Alternatively, row reduce the set of vectors to find the two that are linearly independent and then take the cross product. Your pick.
Thanks for responding... The first recommendation with choosing an 'a' sounds familiar. However, I don't exactly understand how that determines a vector that is perpendicular to the subspace formed by the three vectors.
I'm a bit lost on the concept... Having a hard time visualizing the problem.
v1*u=0
v2*u=0
v3*u=0
where u is a vector, right?
Could someone briefly explain why that works? I apologize if this is painfully obvious...
Thanks again for your help
If the dot product of two vectors is zero, they are orthogonal (practically by definition).
So if the dot product of a vector with all three of the v's is zero, then it must be orthogonal to all three
u.v1=0 means ux-uy+2*uz=0. u.v2=0 means 2*ux+uy+3*uz=0. You do the third one. So just three equations in three unknowns. You won't get a unique nonzero solution, but you can still find one, yes?
Thank you. I understand now what you did any why. However, now I'm having difficulty coming up with a non-zero vector through that 3x3 matrix. So I don't see how to find a unique nonzero solution-- I see why I can't just solve for one.
Any pointers?Thanks again. This is my matrix:
1 -1 2
2 1 3
1 -4 3
You can just solve for one. I don't really see the problem. Can you post more specifically what equations you are trying to solve? You will find you can't 'solve' for all of the variables. Just set x=1 and determine y and z.
Have you noticed that the three vectors given are not independent? In fact, it is IMPOSSIBLE to have, in 3 dimensions, a non-zero vector that is orthogonal to each of the independent vectors. Do you remember anything from Calculus about finding a vector that is orthogonal to two given vectors.
