Proving Trace Independence in Linear Algebra Homework
The discussion focuses on proving that the trace of a matrix is independent of the chosen orthonormal basis. It begins with the definition of trace as the sum of the inner products involving the matrix and basis vectors. Participants note that trace relates to eigenvalues, which remain constant across different bases. The challenge lies in expressing the relationship between a matrix and its representation in another basis to demonstrate this independence. Ultimately, the conversation emphasizes the need to connect these concepts to solidify the proof of basis independence for the trace.
zheng89120
let:
Trace(A) = Ʃ(i=1..n) (ei|A|ei)
Show that trace is independent of the orthonormal basis chosen.
linear algebra
trace is related to the eigenvalues, which are constant?
zheng89120 said:
let:
linear algebra
IF A a diagonalizable and IF the ei happen to be eigenvectors, then sure, it's easy to see the trace is the sum of the eigenvalues. But how does that help you show it's basis independent? How do you write the relation between A and A written in a different basis?
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 30 ·
