Linear Algebra Solving a System of LE
6 replies · 2K views · last reply
Workout
Okay here's my system of equations:
x − 3y − 2z = 0
−x + 2y + z = 0
2x + 4y + 6z = 0
Solve the following systems using Gaussian elimination
I put it in a matrix and did Gaussian elimination.
But I can't find a unique solution and it doesn't end up working out. Is this true? Or am I just making a mistake?
How can we tell without seeing what you did? Why would you expect a unique solution? Show us your work.
x − 3y − 2z = 0
−x + 2y + z = 0
2x + 4y + 6z = 0
As LCKurtz said, show us what you did.
Also, don't blow away the homework template - it's there for a reason.
2R2 + R2 = | 1 -3 -2 0 |
-1 2 1 0
0 8 8 0
R1 + R2 = | 0 -3 -2 0 |
0 -1 -1 0
0 8 8 0
8R + R3 = | 1 -3 -2 0 |
0 -1 -1 0
0 0 0 0
So I was left with 2 equations.
x -3y -2z = 0
-y -z = 0
And I'm just stuck.
Basically when I solve it I get z = 0
then y = -z
and x = -z
There's no unique solution I guess. I was specifically looking for a unique solution. I think that was my problem.
So far, so good, but you can do just a bit more to completely reduce your matrix. You should end up here:
$$ \begin{bmatrix} 1 & 0 & 1 \\ 0 & 1 & 1\\ 0 & 0 & 0 \end{bmatrix}$$
This is shorthand for the system
x + z = 0
y + z = 0
Geometrically, what you have is two planes in space that intersect in a line.
then y = -z
and x = -z
It really makes no sense to "get z= 0" and then have a solution that involves z!
It should have been obvious from the start that, since we have "= 0" on the right side of each equation (this was a "homogeneous" system), x= y= z= 0 is a solution. So if there had been a unique solution, it would have been trivial.
