Is a Vector Perpendicular to the Sum of Two Perpendicular Vectors?
The discussion revolves around proving that if a vector u is perpendicular to two vectors v and w, then u is also perpendicular to their sum v+w. The problem also extends to showing that u is perpendicular to a linear combination of v and w for any scalars s and t.
  • Participants explore the relationship between the dot product and the concept of perpendicularity. There are attempts to apply the distributive property of the dot product to express u.(v+w) in terms of u.v and u.w.
Participants are actively engaging with the problem, questioning assumptions, and exploring different approaches. Some have suggested using the dot product to clarify the relationships between the vectors, while others are attempting to understand the implications of the properties of perpendicular vectors.
Some participants express uncertainty about their background knowledge and the material covered in their lectures, indicating a potential gap in understanding the underlying concepts.
sdoyle
Prove that if a vector u, is perpendicular to both v and w, then u is also perpendicular to v+w. More generally, show that u (perp) (sv+tw) for all scalars s and t.
I was thinking that the cross product would be relevant.
I'm not quite sure where to start. I tried to use w[-wy, wx] and so forth, but I honestly don't understand their full meanings. Any help would be appreciated
I think you ought to be thinking about the dot product. How do you express the notion two vectors are perpendicular in terms of the dot product?
If u is perpendicular to v and w, then v and w should lie on the same plane, correct? Thus if v+w, is also perpendicular to u, then what can you say about the vectors, v,u and v+w ?
EDIT: I believe Dick's method is more feasible than what I was trying to do.
that u.(v+w)=0?
Right. u.(v+w)=0 says u and v+w are perpendicular. Does that follow from u.v=0 and u.w=0?
Yes? Because both v and w would have to be perpendicular to u? I'm not really sure though...
The problem says "u is perpendicular to both v and w". That means u.v=0 and u.w=0. What can you conclude about u.(v+w) and why?
I really don't know.. I'm sorry. I don't think that I have enough background knowledge, we've only had one lecture.
Write out u.v + u.w and u.(v+w)
u.v=-u.w? Because of distributive laws?
By the distributive laws, can you expand u.(v+w)?
You should be able to see that u.v + u.w = u.(v+w) just by writing out the terms on each side
No. Because of distributive law u.(v+w)=u.v+u.w. Doesn't that look more like a 'distributive law'?
right...
but we know that u.(v+w)=0 . Wouldn't that imply that u.v+u.w=0?
Actually, you knew that u.(v+w)=u.v + u.w, from the question, you deduced that u.v=0 and u.w=0
So u.(v+w)=0, which means?
that the vector u is perpendicular to v+w?
Yes.
Now you want to prove that u is perpendicular to (sv+tw) for all scalars s and t.
Now consider what u.(sv+tw) expands out to be.
You don't know u.(v+w)=0. That's what you are trying to prove. What you know is that u.v=0 and u.w=0.
right but u.(v+w)=u.v+u.w
=0+0
= 0
In terms of the scalars any number multiplied by zero will yield zero
