Linear approximation of Tan(44)
To find the linear approximation of tan(44 degrees), the function f(x) = tan(44 + x) is used, with x set to -1 to approximate tan(44). The derivative f'(x) = sec²(44 + x) is applied, leading to the linear approximation formula L(x) = f(a) + f'(a)(x - a). The initial attempt resulted in an incorrect value of -1 instead of the expected 0.965 due to confusion with degrees and radians. The discussion concludes that using radians simplifies the process and yields the correct approximation.
PsychStudent
Find the linear approximation of tan(44)
f(x) = tan(44 + x), let x = a = 1
f`(x) = sec2(44+x)
L(x) = f(a) + f`(a)(x-a)
L(x) = 1 + 2(x-1)
L(0) = 1 + 2(0-1) = -1 (Answer should be approx. 0.965)
Where am I going wrong? X should be zero, because tan(44+0) is what I'm trying to find the approximation of, right?
I think you want to find tan(44 degrees) by expanding tan(45+x) where x=(-1). But be careful about the derivatives when you are working in degrees. I think you are better off expanding tan(pi/4+x) (since pi/4=45 degrees) and then putting x=(-1) degrees, expressed in radians, of course.
Well, that'll teach me never to use degrees again. It worked!
Thanks!
Yeah, degrees aren't fun. They just represent extra work.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 21 ·
