How Does Temperature Affect a Pendulum Clock in Alaska?
Temperature significantly affects the accuracy of a pendulum clock in Alaska due to the linear expansion of the brass rod. When the temperature drops from 19.5°C to -25.5°C, the rod shortens, resulting in a decreased period of the pendulum. The calculations show that the new period is approximately 2.8358 seconds, which leads to the clock running slow over a 24-hour period. Instead of measuring a full 24 hours, the clock would read approximately 23 hours, 59 minutes, and 36.56 seconds. This illustrates the impact of temperature on pendulum clocks and the necessity for recalibration in extreme conditions.
castrodisastro
A clock based on a simple pendulum is situated outdoors in Anchorage, Alaska. The pendulum consists of a mass of 1.00kg that is hanging from a thin brass rod that is 2.000m long. The clock is calibrated perfectly during a summer day with an average temperature of 19.5°C. During the winter, the average temperature over one 24-h period is −25.5°C. Find the time elapsed for that period according to the simple pendulum clock.
Tinitial = 19.5 °C = 292.5 K
Tfinal = -25.5 °C = 247.5 K
ΔT = -45 K
mp = 1.00 kg
Lrod = 2.00 m
αbrass=19*10-6/°C
Ltotal=L+α(ΔT)L
T=2\pi\sqrt{}(L/G)
I calculate the change in length due to the linear expansion of the brass rod
Ltotal=(2.00 m)+(19*10-6)(45 K)(2.00 m)
Ltotal=(2.00 m)+(-1.71*10-3)
Ltotal=(1.9983 m)
The I calculated the length of the period.
T=2pi(1.99/(9.81m/s2))\frac{1}{2}
T=2pi(0.451 s)
T=2.8358 s
I submitted this answer to my online homework but it was incorrect. I think it has something to do with how the question includes "...winter, the average temperature over one 24 -h period is -25.5 °C. Find the time elapsed for that period according..." but I don't understand if it is asking for something more.
Any Help is appreciated.
Thanks in advance
Please don't be rude
I will gladly provide more information on my calculations.
You would be claiming, if your answer were correct, that over a 24-hour period, only 2.8358 second elapses on the clock. Doesn't sound right, does it?
So if the rod shortens, the period of the pendulum would be shorter, the time elapsed on the clock during a 24 hour period would more than 24 hours.
If the period was originally 2.8370, it is now 2.8358
If a 24 hour period is 86,400 seconds, one period of the pendulum is 2.8370 seconds, it would take
(86,400 s)/(2.8370 s/period) = 3,0454.705 periods originally.
Would I then multiply 3,0454.705 periods by the new length of the period 2.8358 seconds to see how many seconds would elapse on the clock after the same number of periods required for 24 hours before the rod contracted.
(3,0454.705 periods)(2.8358 s/period) = 86,363.45244 s
(86,363.45244 seconds)/(3600s/h) = 23.9898 hours
So does this mean that after 24 hours, the clock would read 23 hours 59 hours 23.5 seconds.?
You kinda have the right idea, but you're holding the wrong quantity constant. It's not the number of periods that stays the same; it's the actual time elapsed that remains at 24 hours for both cases. You want to calculate the number of shortened-rod periods that fit into that time interval and then figure out what reading that corresponds to on the clock.
Likes 1 person
If the period of the shortened rod is 2.8358 seconds, then during a 24 hour day, the pendulum experiences 3,0467.593 periods.
3,0467.593 periods is 100.0423% of the original number of periods. Would this mean that the clock would read
24 h + (24 h*100.0423%) = 24 hours, 0 minutes, and 36.56 seconds
That makes sense, hopefully that is correct.
Thanks, I just submitted that answer to my online homework and it was correct. I appreciate the help
You're welcome. Glad you figured it out.
  • · Replies 17 ·
10K
  • · Replies 17 ·
19K
