Linear Operator/transformation Help
  • Thread starter Thread starter Spraypaint
    Linear
The problem involves a linear operator L defined on R^3, with specific outputs for three given vectors. The task is to compute L(1,2,3) using the properties of linear transformations.
  • Participants discuss expressing the vector (1,2,3) as a linear combination of the provided vectors. There is exploration of how to apply the linearity of L to compute the desired transformation.
Participants are actively engaging with the problem, clarifying their understanding of linear transformations and discussing the necessary steps to express (1,2,3) in terms of the other vectors. Some guidance has been provided regarding the use of linear combinations and the application of L to those combinations.
There is an emphasis on understanding the definitions and properties of linear transformations, as well as the need to find coefficients for the linear combination. Participants are also navigating through potential misunderstandings about the order of operations in applying L.
Spraypaint
Let L: R^3 -> R^3 be a linear operator. Given that L(1,1,-1)^T = (2,3,4)^T, L(1,-1,1)^T = (1,5,1)^T, and L(-1,1,1)^T = (2,0,0)^T, Compute L(1,2,3)^T. Justify your answer.
None.
I honestly do not really have a clue. I have an understanding on linear transformations and how they must satisfy the addition and scalar multiplication, but I don't know how to go about doing this question.
If you understand that L is a linear transformation, then you just have to figure out a way to express (1,2,3) in the form a*(1,1,-1)+b*(1,-1,1)+c*(-1,1,1), right?
I assume "^T" mean transpose. You need to write (1,2,3) as a linear combination of the other vectors you were given. Then use the fact that L is linear to compute L(1,2,3).
So my understanding of the question is to find how the linear transformation in this problem is defined, and use that to solve for L(1,2,3). Is this wrong?
You are given how the linear transformation is defined, i.e. the three values. But yes, you will use those definitions along with the fact that L is linear to solve for L(1,2,3).
So going on with this idea, you would get three equations ( a + b - c, a - b + c, -a +b +c). Do you set this equal to 1,2,3? Or am I completely off?
Yes, you set it equal to (1,2,3) and figure out a, b and c. Then apply L to the sum.
[edit]
Sorry, I think I understand now. I should do a(2,3,4) + b(1,5,1) + c(-1,1,1), and use the a,b,c values I got from the other part to solve for L(1,2,3), right?
No, you need those at the end in order to get a final result for L(1,2,3).
Noooo. You'll need those to get the answer. If v=a*v1+b*v2+c*v3 then L(v)=a*L(v1)+b*L(v2)+c*L(v3). You'll need L(v1), L(v2) and L(v3) to get the final answer.
Thank you guys, it makes sense, you surely made my day. =)
