Valid Method for Proving Matrix Equation with Independent Variables
The discussion focuses on proving a matrix equation involving independent variables in a statistical context. The user derived a matrix equation for W1 and W2 based on given parameters and is exploring whether setting specific values for sigma and equating Y1 to Z1 and Y2 to Z2 is a valid approach. It is clarified that one cannot arbitrarily set these values and must instead derive Z from the equation W = RZ, ensuring that Z's entries are independent. The key takeaway is that the user should compute Z as R^{-1}SY and demonstrate the independence of its elements, likely by showing their covariance is zero. This method will validate the relationship between the matrices as required.
island-boy
after a series of computations, I was able to get the following matrix equation from the given of a problem:
\[\left( \begin{array} {ccc} W_1 \\ W_2 \end{array} \right)\] = <br /> \[\left( \begin{array} {ccc} \frac{\sigma_{11}}{\sqrt{\sigma_{11}^2 + \sigma_{12}^2}} &amp; \frac{\sigma_{12}}{\sqrt{\sigma_{11}^2 + \sigma_{12}^2}} \\ \frac{\sigma_{21}}{\sqrt{\sigma_{21}^2 + \sigma_{22}^2}} &amp; \frac{\sigma_{22}}{\sqrt{\sigma_{21}^2 + \sigma_{22}^2}}\end{array} \right)\] \[\left( \begin{array} {ccc} Y_1 \\ Y_2 \end{array} \right)\]
where Y1 and Y2 are independent processes.
the correlation of W1 and W2 was given as follows:
\rho = \frac{\sigma_{11}\sigma_{21} + \sigma_{12}\sigma_{22}}{\sqrt{\sigma_{11}^2 + \sigma_{12}^2}\sqrt{\sigma_{21}^2 + \sigma_{22}^2}}
Now what the problem asks is that I be able to show the following matrix equation to be true:
\[\left( \begin{array} {ccc} W_1 \\ W_2 \end{array} \right)\] = <br /> \[\left( \begin{array} {ccc} 1 &amp; 0 \\ \rho &amp; \sqrt{1 - \rho^2} \end{array} \right)\] \[\left( \begin{array} {ccc} Z_1 \\ Z_2 \end{array} \right)\]
where Z1 and Z2 are independent
and rho is the correlation of W1 and W2.
My question is:
can I just let
\sigma_{11} = 1
\sigma_{12} = 0
and just let
Y1 = Z1
Y2 = Z2?
cause if I did so, then the matrix equation that I want to prove is satisfied.
that is, the following are now true:
\rho = \frac{\sigma_{21}}{\sqrt{\sigma_{21}^2 + \sigma_{22}^2}}
\sqrt{1 - \rho^2} = \frac{\sigma_{22}}{\sqrt{\sigma_{21}^2 + \sigma_{22}^2}}
Is this a valid way of proving?
or should I have to find a matrix linear transformation to transfrom the first equation that I got into the required equation? cause if that's the way that it shouldbe done, then I'm not sure how to proceed about it.
thanks for the help.
Let W denote the left side of this equation, let S denote the 2x2 matrix on the right side, and let Y denote what you think it denotes.
Let R denote the 2x2 matrix on the right side of this equation, and let Z denote what you think it does.
So you have W = SY and you want to show that if W = RZ, then the entries of Z are independent. You can't go setting \sigma _{ij} and Zi to whatever you like. What kind of question would that be? Anyways, if you want to get W = RZ, then it's equivalent to get SY = RZ. In order to get this, what must Z be? Clearly, Z = R-1SY. So look at R-1SY, and show it's entires to be independent. Use the fact that the entries of Y are independent, and that the entries of W have correlation \rho.
hi thanks for replying
actually, what I need to show is that I can write W in the form RZ where Z are independent.
that is, defining W, S, Y, R, and Z below, and given W = SY where Y are independent, I must show that I can write W as W = RZ where Z are independent.
does what you have written still apply?
thanks again.
Yes. ,
hi AKG,
after thinking it throrughly, I think I understand what you meant.
I only need to solve for Z = R^{-1}SY
and then I show the elements of Z are independent of each other (possibly by showing that their covariance is 0)
Thanks for you help! cheers!
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
