Linear transformations + writing of output matrix
4 replies · 2K views · last reply
JamesGoh
Given the following defined transformation
[itex]T(a + bt+ct^{2}) = (a+c) - (c+b)t + (a+b+c)t^{2}[/itex]
find the matrix with respect to the standard basis
From my understanding, the standard basis for a 3 element vector would
be
[itex](0,0,1)^{T} (0,1,0)^{T} (1,0,0)^{T}[/itex]
T(u+v)= T(u) + T(v)
λT(v) = T(λv)
okay, if I used the defined transformation, I get the following when I put any of the standard basis into the transformation
[itex]T(0,0,1)^{T}=1 - t + t^{2}<br /> <br /> <br /> <br /> T(0,1,0)^{T} = 0 -t + t^{2}<br /> <br /> <br /> <br /> T(1,0,0)^{T} = 1 - 0 + t^{2}<br /> [/itex]
If I am correct, the matrix should be the following
1 -1 1
0 -1 1
1 0 1
However, the tutorial answers have it in the form
1 0 1
-1 -1 0
1 1 1
Shouldn't my answer be correct, since the [itex]t[/itex] and [itex]t^{2}[/itex] terms are different parts of a linear equation which is why they can't be in the same column ?
T(x) = A.x
where
x = [c b a]^T
A is the transformation matrix
The way you have put your A matrix, we would need to do following
T(p) = p.A
p = [c b a]
evidently, the "standard basis" being referred to is {1,t,t2}.
that is: a+bt+ct2<---> (a,b,c)
(1,0,0) <--> 1
(0,1,0) <--> t
(0,0,1) <--> t2
with respect to a given basis, B = {v1,...,vn}, the matrix of a linear transformation T:V-->V, [T]B, is the matrix such that:
[T]B[vj]B = [T(vj)]B,
where the multiplication on the left is an nxn matrix multiplied by an nx1 matrix.
of course, [vj]B = [0,0,...1,...,0]B, where the 1 is in the j-th place, which then gives us the j-th column of [T]B.
Does this case of "standard basis" only apply for any 3-element vector input written in the form of a parabolic equation ?
Yes. Your "standard basis", <1, 0, 0>, <0, 1, 0>, and <0, 0, 1>, would be correct for [itex]R^3[/itex]. Of course, the assignment <1, 0, 0>->1, <0, 1, 0>->t, <0, 0, 1>->[itex]t^2[/itex] maps one to the other.
