Linearly Independent Sets and Bases
The discussion focuses on proving that any set of linearly independent vectors \( S = \{v_1, \ldots, v_k\} \) in a subspace \( V \) of \( \mathbb{R}^n \) can be extended to form a basis for \( V \). Participants emphasize the necessity of demonstrating that the extended set spans \( V \) while maintaining linear independence. The approach involves adding vectors not in the span of \( S \) one at a time and ensuring that the resulting set remains linearly independent. The conversation also clarifies that the basis for \( V \) must be a superset of any basis for \( S \).
  • Understanding of linear independence and dependence
  • Familiarity with vector spaces and subspaces
  • Knowledge of basis and dimension concepts in linear algebra
  • Proficiency in constructing linear combinations of vectors
  • Study the process of extending linearly independent sets to bases in vector spaces
  • Learn about the dimension theorem in linear algebra
  • Explore the concept of spanning sets and their properties
  • Investigate examples of bases in various vector spaces, including \( \mathbb{R}^n \)
This discussion is beneficial for students and educators in linear algebra, particularly those studying vector spaces, linear independence, and basis extension. It is also useful for anyone seeking to deepen their understanding of the foundational concepts in linear algebra.
pollytree
V is a subspace of Rn and S={v1,...,vk} is a set of linearly independent vector in V. I have to prove that any list of linearly independent vectors can be extended to a basis for V.
None that I can think of.
So to be a basis, the vectors must be linearly independent (which is given) and span V. I think we also have to show that the number of elements in the basis is equal to the dimension of V. We have a hint that says we can prove the statement above by adding vectors which are not in span S one at a time until we span all of V and arguing that the result is linearly independent.
But I'm not really sure where to begin on this question. Any help would be great! Thanks :D
Let {e1,...,en} be a standard basis. Then set {e1,...,en, v1} is linearly dependent, so
\sum \alpha_i e_i+\beta v_1=0
Cetrainly \beta\neq 0, and \alpha_i\neq 0 for some i. Show that {e1,...,ei-1, ei+1,..., en, v1} is a base. Applying repeatedly this procedure, we may "inject" all the v's into the basis. Show that in each step we can discard one of the e's (and not the previously added v's), that's where linear independence is needed.
Good luck.
I would show that any S could be extended to be a basis for V, then show that a basis for V can be extended to be a basis for Rn.
Let B be a basis for S, what would the minimal subset of B look like that spans V? Ask your self a similar question to go from V to Rn
Sorry, but this makes no sense to me. The problem was to show that any such S could be extended to a basis for V and there is no mention of Rn.
This also makes no sense. S is a set of vectors, not a vector space and so has no "basis". Even if S were a subspace of V, any basis for V would have to be a superset of a basis for S, not a subset.
Unnecessary- the problem says nothing about Rn.
Sorry I miss read the problem, I thought it was to prove that S could be extended to be a basis for Rn. But as you stated my first step is his actual question.
Here is what I was thinking, if it's wrong please let me know!
V has a basis since it’s a subspace, and this means every vector in V can be expressed as a linear combination of the elements of that basis.
Let B be the minimal set of basis vectors of V needed to compose a linear combination of all vectors in S (we know this set exist since S is a subset of vector space V, and since V is a subspace of Rn, it's basis has to be countable).
The basis of V - B union S should be a basis for V right?
