Load on ladder leaning against a wall
  • Thread starter Thread starter engcon
    Load Wall
The discussion revolves around solving a physics problem involving a ladder leaning against a wall, specifically analyzing the forces and moments acting on the system. The ladder is positioned at a 30-degree angle with an 800N load placed three-quarters of the way up. The key equations for equilibrium include Fnet = 0 in both x and y directions, and Mnet = 0 for torque. By denoting the ladder's length as L, participants successfully derived the necessary equations to find the reaction force (R) and its angle (theta).
  • Understanding of static equilibrium principles
  • Knowledge of free body diagrams
  • Familiarity with torque and moment calculations
  • Basic trigonometry for angle calculations
  • Study the concept of static equilibrium in physics
  • Learn how to draw and analyze free body diagrams
  • Explore torque calculations and their applications in mechanics
  • Investigate the effects of friction on static systems
Students of physics, educators teaching mechanics, and anyone interested in understanding the principles of static equilibrium and force analysis in real-world applications.
engcon
Hello, I got this problem from a book
"A light ladder leans against a perfetly smooth vertical wall at an angle of 30 degrees to the horizontal. A load of 800N is placed 3-quarters of the way up the ladder. If the ladder rests on a rough horizontal surface which prevents slipping, find the magnitude and direction of the reaction between the ladder and the ground"
Since the system is in equilibrium, I resolved vertically and got
R sin(theta) = 800
where R is the reaction force, and theta is the angle of the reaction force with the horizontal.
The problem is I can't get another equation so that I can find R and theta.
Any help is appreciated, thanks!
Okay, first of all, my definition of "reaction" is the normal force produced by any surface, which I think does not coincide with your definition. In anycase, This problem involves three equations which are easily solved.
1. Fnet = 0 (in the x direction)
2. Fnet = 0 (in the y direction)
3. Mnet = 0 (torque, no rotation)
The frictionless wall will only produce a force in x. The floor will only produce a force in y. The friction at ladder's base will produce a force in -x. The 800 N load will produce a force in the -y.
Now for moments. Take the moments about the ladder's base (you can choose any point, but this point is particularly easy. Then the two forces that will create a torque around this point will be the 800N load (counter clockwise) and the reaction force of the wall (clockwise). They must sum up to zero.
Go get em =)
Go get em =)
No mention of the ladder length is made, so I cannot use moments
Are you sure? Try denoting the length of the ladder as L. Leave it as L (you don't need to substitute a number), and see what happens.
Solved
Did that, and solved it
Thanks
  • · Replies 20 ·
  • · Replies 27 ·
