Mattius_
- 8
- 0
Can you put a password on a windows folder? If not, what is the next best thing?
The discussion revolves around methods to protect data in Windows folders without using a password. Participants explore various techniques, including folder encryption, NTFS permissions, and alternative approaches like compression and password protection of zip files. The conversation covers both theoretical and practical aspects of data protection on Windows operating systems.
Participants express varying opinions on the best methods for protecting folder data, with no clear consensus on a single approach. The discussion includes both agreement on the necessity of NTFS for certain features and disagreement on the feasibility of removing administrator rights.
Limitations include the dependence on specific Windows versions and file systems, as well as the unresolved nature of the maximum size and directory levels for encrypted zip files.
Mattius_ said:Can you put a password on a windows folder? If not, what is the next best thing?
Another thing is that i don't believe you can remove the Administrator's rights over any folder you create, that's why it helps if you're the administrator (also because you might need Admin rights to modify the security information).
Triss said:I am sure it would be way easier on a linux machine...
What is the maximum size and number of directory levels for an encrypted zip file? I would like to encrypt the entire directory structure (~8 GB) on my portable USB hard drive without losing the organizational structure.-Job- said:As it was mentioned here, if you have NTFS, which you probably do (unless you have Win 9x, Me, or an XP, 2000, 2003 installation on top of an old one) then you can create a folder, right-click on it, select properties, on the security tab you can make sure that yours is the only user account that has read/write access. A couple of things to keep in mind is that there are system accounts that the Operating System or services use which generally you wouldn't have to worry about unless you are using your folder for more than just storing data. Another thing is that i don't believe you can remove the Administrator's rights over any folder you create, that's why it helps if you're the administrator (also because you might need Admin rights to modify the security information).
Encription sounds more like what you need, of course you'd need to encript/decript it everytime you want to use the folder. Maybe a better alternative is to simply compress it with a .zip program and password protect it.
