Logic circuits for nuclear reactor shutdown and prime number checker
8 replies · 4K views
hallerman
1. A nuclear power plant contains three danger sensors X, Y and Z that can shut down the plant. Sensor Z is in such a senstive location that it has a backup B. The plant is to be shut down if two of the three sensors indicate danger. However, with exception, sensor Z is the only registering danger sensor so that the plant to be shut down. Design the logic circuit of danger sensors.
2. Let A, B, C and D represent the binary digits of a decimal number in the range 0 to 15. Construct a simplified expression and draw the logic circuit diagram that will give a prime number checker.
Karnaugh map and truth table
1. I have no idea how to incorporate the back-up and also what the third sentence means. Any clues, please?
2. I got Y = A'B'C + B'CD + A'BD + BC'D from the Karnaugh map. Is that the correct simplified expression?
That is too ambiguous to arrive at a single solution.
However, were it an exam question there is no point in evading it, so I'd nominate the interpretation I'd use and arrive at a solution based on that interpretation.
If B is the backup for Z, then it is probably intended that the plant shut down if 2 out X,Y and B go high, in addition to shutting down if Z goes high.
However, I am not comfortable with this interpretation as it deprecates the term "backup", because I don't have B acting as a true backup. But I can't see any other way of including the "2 out of 3" guide.
Write the list of numbers that this expression will signal as prime.
If you have a k map, you have at least went through part of the design process. Why are you questioning your k map? Are you not sure of the truth table or that you have processed the k map correctly?
How can you hope to implement a design if you don't understand the specifications? You expect us to guess what the problem is? Ask your teacher what he means and get back to us.
I have done the k map. I'm only hoping that you might check if the answer's correct, as I might have made a mistake in my solution. Please!
I've talked with the teacher. The backup has no utility in this problem. I did the problem by two different methods:
1. Output = XY + YZ + ZX + Z = XY + Z
2. I formed the truth table for X, Y, Z & Output, and then, I did a k map and got the same answer.
Are both methods equally valid?
Yes, both methods are valid but sometimes a K-map gives a simpler implementation. But I have no confidence in what the problem actually requires. Your solution is to shut down the plant if either Z or both X and Y activate. If that is what is required, why doesn't the problem say that, and why does it mention the backup B if it is irrelevant?
I would give your instructor an F for that problem statement if you have quoted him exactly.
I think I agree with you. :smile:
Btw, I got Y = A'B'C + B'CD + A'BD + BC'D for the four-bit prime number checker. I'm wondering if there's any way to further simplify this expression. I haven't found any way, hence my question.
