Long insulated copper rod with 2 temperatures find T(x,t)
  • Thread starter Thread starter samee
    Copper Rod
The discussion centers on solving the heat equation for a long insulated copper rod with boundary temperatures of 0°C at x=0m and 100°C at x=2m. The initial temperature distribution is defined as T(x,0)={100x for 0 PREREQUISITES
  • Understanding of the heat equation and diffusion processes.
  • Familiarity with boundary value problems and initial conditions.
  • Knowledge of separation of variables technique in solving partial differential equations.
  • Basic concepts of Fourier Series for solving heat equations.
  • Study the derivation of the heat equation and its applications in thermal analysis.
  • Learn about boundary conditions and their implications in solving differential equations.
  • Explore Fourier Series and their role in solving problems involving heat conduction.
  • Practice solving similar problems involving temperature distribution in rods or plates.
Students studying heat transfer, physicists, and engineers involved in thermal analysis and material science, particularly those focusing on the behavior of conductive materials under varying temperature conditions.
samee
A long copper rod with insulated lateral surface has its left end maintained at a temperature of 0C and its right end, at x=2m , maintained at 100C . Determine the temperature T as a function of time and coordinate if the initial condition is given by
T(x,0)={ 100x, 0<x<1
________100, 1<x<2
So I'm assuming this question is also actually just a diffusion equation or a wave equation, since that's what the rest of our homework was on. Alpha2uxx=ut
and
u(x,t)=X(x)T(t)=(C1coskx+C2sinkx)e-K2alpha2t+C3+C4x
I asked another question like this one... So here I have a rod with a temperature difference. These differences are being maintained, so I guess what I'm doing i assuming that it's in equilibrium and the temperature isn't shifting at all. I'm asked for the temperature as a function of time and coordinate, but that doesn't make sense if time isn't a factor. In the initial condition it certainly is not a factor. So I guess I need to set boundary conditions as given?
I know u(x,0)={X(x)100x 0<x<1
_____________X(x)100 1<x<2
and 0<x<2 for the whole problem.
Now, I really need to set my boundary conditions, right? I guess I can say that since the rod is finite, and 0<x<2, anything less than zero or greater than 2 is zero. Therefore;
u(0,t)=0 and u(2,t)=0.
If u(0,t)=(C1)e-K2alpha2t+C3=0
This would mean that C1=0 and C3=0, so
u(x,t)=(C2sinkx)e-K2alpha2t+C4x=X(x)T(t)If u(2,t)=(C2sink2)e-K2alpha2t+C42=0
This would mean that C4=0 as well. Also,
(C2sink2)e-K2alpha2t=0
If C2 IS NOT 0, then sin2k=0, and 2k=npi. Therefore k=npi/2 and...
u(x,t)=C2sin(xnpi/2)e-(npialpha/2)2t
SOOOO! IF I did my boundary conditions right, I can then plug it back into the original equation and get;
u(x,t)={ X(x)=(1/100x)C2sin(xnpi/2)e-(npialpha/2)2t for 0<x<1
________X(x)=(1/100)C2sin(xnpi/2)e-(npialpha/2)2t for 1<x<2NOW what do I do next?
Your rod is not in thermal equilibrium unti t = ∞. It starts out per your initial condition
T(x,0) and obviously ends up with T varying linearly with x, assuming temperature-independent conductivity, density and specific heat.
I haven't done the problem but I would assume separation-of-variables solution of the heat equation as you state. And hope like hell!
You likely need more help than I can give you here and I'm not sure I should bother with this since you abandoned the last thread I tried to help you. But I will see how it goes...
________100, 1<x<2
So you are going to just guess which it is?
and
Where did that "solution" come from? It doesn't look correct. Do you know what is missing? Please show your steps to get that or, if you copied it from somewhere, fix it.
But it isn't in equilibrium. The problem clearly states to determine u(x,t) as a function of time ##t## and position ##x##.
I know u(x,0)={[STRIKE]X(x)[/STRIKE]100x 0<x<1
_____________[STRIKE]X(x)[/STRIKE]100 1<x<2
That is the initial condition. I have crossed out what shouldn't be there.
Any value of ##x## outside of [0,2] is irrelevant to this problem. There is no rod there.
Therefore;
Why? When I put ##t=0\ ##in there I get ##C_1+C_3 = 0## which just means ##C_1=-C_3##.
Have you studied Fourier Series? Do you know what is missing if you are going to use Fourier Series? There may be other issues but that's enough for now. Please respond to each comment if you want to continue.
  • · Replies 67 ·
9K
