Looking for General solution for a difference equation
ivyhawk
At+1=(At+r)/(At+r+1)
A1=constant
I know I can set At+1=At=A and solve for a special solution.
What would be a general solution?
I am not taking a course in Difference Equation, and this is not my homework but I encounter a similar question and I reduce it to this form.
Thanks
Or One step further, how to solve this one?
(1+r)A_t+1-A_t+A_t+1*A_t=r
A_t means A with t subsciptI don't think it is as easy as it looks.
It doesn't even look like anything. :-p
Is your second one meant to be
(1+r)At+1-At+At+1*At=r ?
Yes That is what I mean. And it is just algebra manipulation of the original equation
Your starting form is
A_{t+1} = \frac{A_t + r}{A_t + r + 1},
which is perhaps more convenient to write as
A_{t+1} = 1 - \frac{1}{A_t+r+1}
What you could to do try to solve it is find A_2 in terms of A_1, plug that into A_3 to get it in terms of A_1, and so on, to see if you can guess what A_t for general t will look like. (I don't know if this one will turn out nice. I did the first couple of steps myself, and it looks like you may want to look into http://en.wikipedia.org/wiki/Continued_fraction (go to the page on periodic continued fractions too). There may be nice solutions for specific values of r or A_1. (Of course, A_1 will be irrelevant as t -> infinity)
Specific solution for A_t is easy to solve
Set A_t=A=A_t+1
We can solve that r=A/(1-A) or the other way, A=(1/2)(-r+(-)(r^2+4r)^1/2
But I still find it very hard to find a general solution.
A general solution is hard to find.
But you can get some idea about the asymptotic behaviour when the sequence is approaching equilibrium A.
So assume your solution is
A_{k}=A+p_{k}
Where the sequence p goes to zero as k increases. At the limit of large k, you can expand the RHS to a taylor series. Because we want a linear easy solution, we will only care about the first order. So:
A+p_{k+1}=1-\frac{1}{A+r+1}\frac{1}{1+\frac{p_{k}}{A+r+1}}=1-\frac{1}{A+r+1}(1-\frac{p_{k}}{A+r+1})
Let A+r+1=b to make it look nicer. Also 1-1/b=A. So:
A+p_{k+1}=A+(1-A)^{2}p_{k}
Or
p_{k+1}-(1-A)^{2}p_{k}=0
So at large k's, the series will be:
A_{k}=A+(1-A)^{2k}
This will be a real approximation only if abs(1-A)<1 (the solution is really stable), and that depends on what value of A you have chose, and what is r.
How did u expand it?
A_{k}=A+p_{k}
Or
A_{k}=A+(1-A)^{2k}
This is a geometrical series:
\frac{1}{1-q}=1+q+q^{2}+q^{3}+...
setting q-> (-q) the terms will occur with alternating signs so the linear approximation will be
\frac{1}{1+q}=1-q
