atyy said:
Aren't they trying to solve the canonical LQG Hamiltonian constraint by finding a perfect spinfoam action?
http://arxiv.org/abs/0905.1670
In a sense you are right. But notice that they have mainly been working on simplicial models, which are fully 4D, and they wish to preserve full 4D covariance (i.e. diffeo symmetry). But in the paper you cite they also have explored how to derive a canonical model (something based on a 3D slice.)
But I think this would not turn out to be the old canonical LQG that we know! They are proceeding "backwards" from what I think Tom Stoer is imagining. You do not first fix a precise canonical LQG and then derive a 4D QG from it. The Bahr Dittrich strategy, I would say, is to first find a good 4D QG---whether simplicial or spin foam or whatever---and then re-invent the corresponding canonical version.
==quote Bahr Dittrich==
We will examine the issue of diffeomorphism symmetry in simplicial models of (quantum) gravity, in particular for Regge calculus. We find that for a solution with curvature there do not exist exact gauge symmetries on the discrete level. Furthermore we derive a canonical formulation that exactly matches the dynamics and hence symmetries of the covariant picture. In this canonical formulation broken symmetries lead to the replacements of constraints by so--called pseudo constraints. These considerations should be taken into account in attempts to connect spin foam models, based on the Regge action, with canonical loop quantum gravity, which aims at implementing proper constraints. We will argue that the long standing problem of finding a consistent constraint algebra for discretized gravity theories is equivalent to the problem of finding an action with exact diffeomorphism symmetries.
==endquote==
tom.stoer said:
I know of no reasonable theory which does not admit a canonical formulation. I worked on QCD and it became clear tome that certain aspects are better addressed in the canonical approach.
I agree! Let's have a canonical formulation of 4D QG! But I see no reason that this should be identical to the old form of LQG. When you walk you do not always put the same foot forward
Today the Loop/Foam people are working on the foam approach and that is what is changing. When that is advanced then they may well advance "on the other foot" and make an entirely new version of the canonical.
Indeed this is how it went historically with Einstein. He provided a fully 4D covariant approach and only much later people discovered how to make a canonical (Arnowitt Deser Misner) that was compatible with it. It took some 47 years between Einstein 1915 and ADM 1962
Perhaps something went wrong during the "old-fashioned" LQG program, but then it should be investigated what exactly went wrong!
I suppose that is a matter of research taste, of what questions you consider fruitful and illuminating to explore. Most physics gambits turn out wrong, and researchers gain insight from working on them, which they carry on and apply to the next version.
I like Bianca Dittrich's taste in what is interesting. Let's see how she spends her time. Perhaps she will come up with a good covariant or "path integral" QG, and then she might work back to a new canonical formulation---QG on a 3D slice, with constraints. And then maybe, as you would like, she may take some time to investigate why the original attempt did not work and remained incomplete. Or once they get the right answer it may be OBVIOUS. Or again, it might still not be obvious but a researcher like Dittrich might not think it worthwhile to look back and investigate the cause of frustration.
I see no compelling reason for us to say now, ahead of time, what should be done.
As I see it, each of these half-dozen approaches gains insight with illuminates the rest, and all are changing. There is no one fixed Loop this or Spin that. Each year or so, there will appear some main article that defines what the approach is, at that moment, approximately.
About Dittrich, we should be on the lookout for these papers that have not yet appeared!
[28] B. Bahr, B. Dittrich, P. Höhn, “
Exact and approximate constraints in 4d Regge calculus,”
to appear
[30] B. Bahr, B. Dittrich,“Improving the action for Regge calculus with cosmological constant,”
to appear
[31] B. Dittrich and L. Freidel, to appear
