Lorentz Transformation: Wave Equation vs. Interval Invariance
  • Context: Graduate
  • Thread starter Thread starter jk22
    Lorentz
The discussion revolves around the derivation of the Lorentz transformation, specifically whether it should begin with the invariance of the wave equation or the invariance of the space-time interval. Participants explore the implications of each approach and the resulting equations.
  • Some participants propose starting the derivation of the Lorentz transformation from the invariance of the wave equation, suggesting it leads to five equations, two of which are wave equations.
  • Others argue that beginning with the invariance of the space-time interval results in only three quadratic equations, questioning the validity of the initial claim regarding the number of equations.
  • A participant expresses skepticism about the historical accuracy of the proposed approaches, suggesting that Lorentz did not start with either method.
  • One participant references vague historical laws as a basis for their claims, prompting criticism regarding the reliability of such sources.
  • Another participant challenges the interpretation of the equations, asserting that the claim of having five independent equations is incorrect and that the derivation process may be misunderstood.
  • There is a mention of the implications of coordinate transformations on understanding phenomena at the speed of light, reflecting on Einstein's inquiries during his time.
Participants do not reach a consensus on the appropriate starting point for deriving the Lorentz transformation, with multiple competing views and interpretations remaining unresolved.
Participants express uncertainty regarding the definitions and implications of the equations involved, as well as the historical context of the Lorentz transformations. There are unresolved questions about the accuracy of the claims made and the sources referenced.
jk22
To find the Lorentz transformation, should it start with the invariance of the wave-equation ?
If so, then it gives 5 equations, 2 of them being wave-equations again.
If however the invariance of the space-time interval is demanded only 3 quadratic equations come out.
Which way should be taken to start relativity ?
I don't believe Lorentz started with either of these approaches. Further, can you provide more detail on what you mean by each alternative. The way I would do either approach, I do not get the number and type of equations you claim.
Where are you getting this from? Can you give references?
I mean in formulas the first way were :
\frac{\partial^2 f}{\partial x^2}-\frac{1}{c^2}\frac{\partial^2 f}{\partial t^2}=0\\=\frac{\partial^2 f}{\partial x'^2}\left[\left(\frac{\partial x'}{\partial x}\right)^2-\frac{1}{c^2}\left(\frac{\partial t'}{\partial t}\right)^2 \right]\\-\frac{1}{c^2}\frac{\partial^2 f}{\partial t'^2}\left[-c^2\left(\frac{\partial t'}{\partial x}\right)^2+\left(\frac{\partial t'}{\partial t}\right)^2 \right]\\+2\frac{\partial^2 f}{\partial x'\partial t'}\left[\frac{\partial x'}{\partial x}\frac{\partial t'}{\partial x}-\frac{1}{c^2}\frac{\partial x'}{\partial t}\frac{\partial t'}{\partial t}\right]\\+\frac{\partial f}{\partial x'}\left[\frac{\partial^2 x'}{\partial x^2}-\frac{1}{c^2}\frac{\partial^2 x'}{\partial t^2}\right]\\+\frac{\partial f}{\partial t'}\left[\frac{\partial^2 t'}{\partial x^2}-\frac{1}{c^2}\frac{\partial^2 t'}{\partial t^2}\right]
as it can be seen the two last equations are wave equations for the change of coordinates.
For example the two last equation would imply :
x'=ax+bt+f(x-ct)+g(x+ct)\\
t'=dx+et+h(x-ct)+k(x+ct)
So is there any hope that the coordinate transformation would allow to know what happens at the speed of light in vacuum $c$, as it was questioned by Einstein at his epoch (I remember having read that but I could not find where again, because Lorentz transformation are diverging at that speed) ?
jk22 said:
I just start from vague laws claimed by physicists during history
"Vague laws" are not a good starting point. Also Wikipedia is not a good source, you need to be looking at textbooks or peer-reviewed papers that specifically talk about how the Lorentz transformations can be derived and from what axioms. Also that Wikipedia article is very long and I don't see anything in it that corresponds to the claims you made in your OP.
Where are you getting all this from?
From the invariance of the wave-equation, by using the chain rule.
In other words, you don't have five equations. You just have one. "Five equations" would mean five independent equations, none of which can be derived from any of the others.
You seem to have a fundamental confusion about how to count "equations" and what it means to "derive" the Lorentz transformations. Searching PF should turn up some good past discussions on this topic. I would strongly recommend checking them out and also looking at the literature on different ways of deriving the Lorentz transformations from particular sets of axioms. That way you will be able to start a new thread with a better basis for discussion.
In the meantime, this thread is closed.
  • · Replies 22 ·
  • · Replies 34 ·
  • · Replies 53 ·
