Why are exponential functions dimensionless?
  • Context: Undergrad
  • Thread starter Thread starter starzero
    Units
3 replies · 3K views
starzero
Hi All and sorry if this is too easy a question but here goes...
Sines, Cosines and the rest of the trig functions are the ratio of two lengths and thus are dimensionless quantities.
That is if I plug in a value for t in sin(ωt) there are no units.
For example the solution of
x'' + ω^2 x = 0 with x(0) = x0 and x'(0) = v0 is given by
x(t) = x0 cos(ωt) + v0/ω sin(ωt)
The units come from the initial conditions not the sine or cosine.
So here is the question...
Same is true ( I believe ) when using the natural exponential function exp(t).
How does one simply explain this.
I tried to reason it out using eulers formula exp(iω) = cos(ω) + i sin(ω) figuring that again we get ratios of lengths,
however in the case where the real part is non-zero we get another exponential (which is not the ratio of lengths)
exp(a +ib) = exp(a)(cos(b) + i sin(b))
Is there a simple explanation as to why we "lose the units" when using the exponential function?
It is not strictly correct to supply any argument with dimensions to an exponential or trig function. Example: [itex]\omega t[/itex] has no dimensions (frequency is 1/time, and time/time is dimensionless).
Why is it incorrect? Consider a series expansion of the exponential function.
[tex]e^x = 1 + x + \frac{1}{2} x^2 + \ldots{}[/tex]
[itex]x[/itex] must be a dimensionless parameter. If it had, say, dimensions of length, how would we add length to 1 and to length squared?
Nevertheless, in physics this strict need is sometimes ignored. As an example, you should take as implicit that [itex]e^t[/itex] is in fact [itex]e^{t/\tau}[/itex] where [itex]\tau[/itex] is 1 in whatever units of time you're working with.
Muphrid said:
It is not strictly correct to supply any argument with dimensions to an exponential or trig function. [..]
Yes indeed, and it may be useful to give an example (of not ignoring this):
http://hyperphysics.phy-astr.gsu.edu/hbase/electric/capdis.html
Thank you both for your fast insightful and illustrative replies.
